Remote Forum (Read Only)
Welcome to Autodesk’s Remote Forums. Share your knowledge, ask questions, and explore popular Remote topics.
how can I access my work computer
5 REPLIES 5
S.AL-MASHTA
780 Views, 5 Replies
how can I access my work computer (remote is installed) with my windows 8 laptop at home?
5 REPLIES 5
asburyj
in reply to: S.AL-MASHTA
You will want to make sure Autodesk Remote is signed in on both systems and that your work computer has Remote Access set to "on"in the Autodesk Remote windows. After doing this your work system should appear on the connect tab of Autodesk Remote from your home system. If it does not, Autodesk Remote may be being blocked on your work network.
The following ports must not be explicitly blocked on either the local machine or any intervening firewall between the local machine and the internet (for both host and client machines):
8090 - 8300 UDP Used for client to host communications,
7182 UDP
8080 - 8090 TCP (outgoing)
80, 443 TCP (outgoing) Used for HTTP and HTTPS communications
Ensure the following domains are not blocked for HTTPS:
*.otoy.com
*.webcl.com
*.otoyserver.com
Jeffry Asbury
rgraham35
I have these ports in our firewall both in and out. The connection of the client does not work unless I reduce the security of the firewall basically open up all ports. So what other ports does this use?
asburyj
in reply to: rgraham35
Those are the only posts I know of. See the ports and domains section of the below doc
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21981875&linkID=9240617
Jeffry Asbury
pendean
Set up Remote Desktop through your server OS: it's a core Windows feature and way more secure than some third party app like this one.
Look at what large companies do, even Autodesk employees aren't allowed to use REMOTE to access company servers.
rgraham35
in reply to: pendean
I agree there are better ways to do it... but for user experience you have to go to view or remote fx.....
I am just after a complete list of ports needed. What Autodesk gives in the link above is not even close to being all you need open... for instance I have seen ports in the 50000 area being used when the connection is active.
