When the connection is slow, you get an information window in the middle of the screen.
This window shows the message " The Network You Are Using Is .....". This window will stay fore ever !!
Is there an function to close it? It overlap everything - you cant work! The speed is ok - but the message window is the biggest problem to work around it!
See attachment
Regards
Frank
This message is designed to show only once per connection. Remote has the ability to re-connect if the connection drops out and this may be causing the message to show more than once. Do you notice Remote having a long lag before this message show up?
