I just noticed that, when importing Faro fls files, the default range filter in ReCap is set to 120 meters. I assume that this is a result of the Faro LS120's maximum range, and any points beyond 120 meters should be considered noise. The Faro X330 has a range of 330 meters and if you don't remember to change this setting, you may lose about 1/3 of your points.
