ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
ReCap Release Notes (Updated: 9/2)
0 REPLIES 0
Message 1 of 1
richiee
4715 Views, 0 Replies
ReCap / ReCap 360 / ReCap 360 Ultimate 2.1.1.2
ReCap [Direct Download]
ReCap 360 / Ultimate [Direct Download]
  • [ReCap 360 / Ultimate] Fix UI glitch when plane snapping in RealView.
  • Fix issue with RCP paths after Save As.
  • Fix issue with published measurements not appearing in some cases.
  • Fix two issues with loading legacy RCP files.
  • Fix issue where deleted regions are still counted against project limit of 61.
  • Fix intermittent crash when moving points between regions.
  • Fix issue where intensity coloring was incorrect in some cases until gradient mode is changed.
  • Fix issue where Leica import can fail in some cases.
  • Fix issue with viewing read-only projects created in older versions.
ReCap / ReCap 360 / ReCap 360 Ultimate 2.1.0.17
  • Support for Leica P16 raw format.
  • Import/Export of Notes from/to CSV.
  • X-axis and Y-axis ortho-measurement.
  • Isolate annotations from the Project Navigator.
  • Option to restore deleted points.
  • [ReCap 360 / Ultimate] Cylinder extraction tool.
  • [ReCap 360 / Ultimate] 'Surface Snap' for perpendicular measurements.
  • [ReCap 360 Ultimate] Performance and Resource improvements in large registration projects.
  • Miscellaneous defect fixes and performance improvements.
ReCap / ReCap 360 / ReCap 360 Ultimate 2.0.2.1 (July hotfix)
  • Fix issue where import fails silently when project directory does not exist.
  • [ReCap 360 Ultimate] Fix crash when rejecting merge of a registration group.
  • Fix issue with loading some legacy RCP data.
  • Fix RCS export such that AutoCAD dynamic UCS features will work properly.
  • Fix issue where UCS is not applied to scans added after the UCS is created.
  • Fix intermittent crash during transition to RealView from click on 3D mirror ball.
  • [ReCap 360 Ultimate] Fix occasional crash when creating or deleting a registration group.
  • Fix problem with resource usage during publish to A360.
  • Ensure image attachments are copied to new project during 'Save As'.
ReCap / ReCap 360 / ReCap 360 Ultimate 2.0.1.5 (May hotfix)
  • Create panorama previews at import time to improve UX
  • Fix issue where height coloring could be lost after editing the limit box
  • Visual improvements to application border & frame
  • Fix issue with import on some non-English operating systems
  • Fix issue with image attachments on some non-English operating systems
  • [ReCap 360 Ultimate] Memory improvement in registration
  • Fix issue with importing multi-scan PTX files with large offset
  • Fix issue with multi-scan PTG containing very small scans
  • [ReCap 360 Ultimate] Fix issue where some failed registrations may report 'green' results
  • Fix issue with unified export of some large-coordinate projects
  • Fix issue where the default camera is not saved correctly for some projects
  • Fix issue where limit box is not updated when survey transform is changed
  • Automatically update map images when UCS changes
  • Removes sign-in requirement at start-up in network mode to enhance off-line use
  • [ReCap 360 Ultimate] Includes authentication of ReCap 360 service student entitlement
ReCap 2.0.0.255: [Direct Download]
Advanced Measurement
  • Measurement is a snap with smart measurement tools.
  • Easily measure diameters and distances between cylinders and planes with automatic shape fitting.
  • Obtain fast and true clearances with a single mouse click.
Advanced Annotation
  • Enhance the value of your point cloud project with tags, notes, pictures and hyperlinks.
  • Automatically sync all your annotations between your desktop and your cloud.
  • Share and sync markups with project collaborators or empower your team to markup a project together.
Search
  • Quickly find marked objects, assets, saved views and project tools with advanced search utilities.
Automatic Registration
(ReCap 360 Ultimate feature only)
  • Combine laser scans easier than ever with target-less automated registration.
  • Quickly, effortlessly and accurately register scans with little to no user interaction.
ReCap 1.4.2.8 (January Hotfix): [Direct Download]
  • An invalid RMS value is displayed for targets in the top-view during registration
  • In some cases, survey alignment is re-applied when going back to registration mode
  • Fix issue where unified export can be incorrect for projects with large coordinate offsets
  • Fix issue with occasional point mismatch on unified export
ReCap 1.4.2.2 (November Hotfix): [Direct Download]
  • ZFS points which have been masked in Z+F Laser Control may be coloured red or yellow in ReCap
  • The Update Origin function could fail for some projects with large coordinate offsets
  • Small 'target' scans in multi-scan PTX files would be placed at 0,0,0, causing issues w/ project extents, etc
  • Group (and project) merge could fail and/or produce incorrect results when the incoming group's base transformation was non-trivial.
  • Occasional crash in indexing, resulting in a 'C++' Assert message.
  • Some legacy issues were causing reduced dynamic intensity range in structured data and incorrect ZFS intensity.
  •  In some edge cases, registration can crash due to some cached information becoming invalid.
ReCap 1.4.1.7 (October Hotfix): [Direct Download]
  • Fix issue with large coordinate Topcon projects
  • Fix issue with incorrect point size after some navigation operations
  • Fix exception upon first launch with large-coordinate, unstructured data formats
  • Fix for ‘Clear Survey Data’ operation
  • Fix issue where the ‘survey’ status of a target could not be changed once set
  • Fix issue where, in some cases, registration results could be incorrect for new scans after reloading a project
  • Small changes to Registration reporting to disambiguate results between normal and target-enhanced modes
ReCap 1.4 (1.4.0.132) New Features:
  • Target-based Accuracy Reporting:
    • Create accuracy reports based on checkerboard or sphere targets.
    • Provide easy-to-read quality information for stakeholders.
    • Use reports to analyze and detect problematic scans.
  • Target-based Registration Refinement:
    • Improve the registration of low feature environments.
    • Automatically extract target center points.
  • Registration rollback:
    • Delete scans without the need to re-register.
(For more information on these new features, please refer to this guide: PDF)
ReCap 1.4 (1.4.0.132) Major Bug fixes:
  • Fix issue where publish to A360 fails silently if illegal characters are in the specified folder name
  • Fix issue where project load could fail if a particular set of selections & filters were applied
  • Fix occasional crash when navigating between View States
  • Fix issue with limit box in projects with a user-defined coordinate system
  • Added workaround for issue where project file can become corrupt after save on some systems
  • Fix issue where project name is incorrect in title bar after Save As
  • Fix issue where certain projects must update cache each time they are launched
  • Fix occasional crash when exporting registration report
  • Fix jitter when navigating the 3D point cloud slowly
  • Improve experience when switching between similar view states
  • Fix issue with missing data after E57 export in projects created with older versions of ReCap
  • Fix issue where RealViews could not load after merging projects in some cases
ReCap 1.3.5.1 (June Hotfix):
  • Issue with reflectance data in FLS scans
  • Indexing issue with some PTX files
  • Fixes the issue in ReCap Photo RCS export when the model is scaled to a very large size
  • Sampling artifacts in long range structured data
  • Visualization issue with some outdoor FLS scans
  • Export to RCS might fail for scans with large coordinates
  • Heartbleed vulnerability fix
ReCap 1.3.4.5 (Hotfix 1):
  • This hotfix fixes the bug in ReCap that export to RCS might fail for project with large coordinates.
ReCap 1.3.4.5 (May Hotfix):
  • Address Heartbleed vulnerability by replacing two affected dlls.
  • Fix the bug that project file might be corrupted or deleted when computer went to sleep or shut down during scan importing.
  • Fix the bug that PTG with only intensity are imported as all-black.
  • Add the support for US Survey unit.
  • Fix the bug that project cannot load on A360 if map images do not exist in temporary cache when publishing.
  • Fix the memory allocation error during registration.
  • Fix the bug that export might fail under certain conditions.
  • Fix the bug that region is not displayed properly when reopened after deletion of points.
  • Fix the bug that project save as function is not copying all support files to destination folder when merging several projects.
ReCap 1.3 (2015) New features/functionalities:
• Integrated Application Manager as software delivery solution which will keep user informed of important product updates, by sending alerts to your desktop.
• Provide more license options: Network license and usage based license.
• Improved Annotation functions: Allows user to edit existing measurement; Allows user to create annotation in Real View; Support title and body for note; Support hyperlink for note; Better look & feel for annotation; provide visual feedback during annotation placement.
• Capture Codec Kit.
• Allow user to quick view registration result.
• Improved display quality of gradient ramp, add support for user-defined label positions.
• Add function to clear all survey data from a project.
ReCap 1.3 (2015) Major Bug fixes:
• Display issue for Project with large coordinates.
• Scans will not index if original raw file is moved or removed.
• Publishing maps only to 360 causes 404 when loading 360 projects.
• Removed scan still displayed in project navigator under specified conditions.
• Unable to customize elevation values.
• Click mirror ball in 3d is not navigating to the nearest scan.
• Index failure caused by temp folder is not set/loaded properly when system is upgraded from K2/1.0.
• Add/Remove Registration Group is not auto-saved.
• Unit conversion error.
• Add folder of ZFS fails due to duplicates if ZFPRJ file exists.
• Selected scan's thumbnail cannot be highlighted after switching during registration.
• User can add notes/annotation to a point where there is no coordinate detected.
• LAS Import does not process intensity.
• Gradient ramp can have duplicated names.
• Export to unified rcs failed if the project contains cropping data.
• Random crash when clicking on mirror balls.
• Crash when opening a rcp file with many deletion selections.
• Crash when cancel during exporting to E57.
• Crash loading RCP with large number of region/selection.
• Crash when remove one folder from search path.
• Survey points cannot be enabled or disabled unless scan is loaded.
• User cannot navigate to the corresponding scan after deleting and adding scans in a project.
• ReCap doesn't colorize raw scans saved in SCENE.
• Open legacy rcp in ReCap 1.2, it's shown in Height display mode by default.
• For some scans RCS exported has no intensity.
• Some pcg can't be imported.
• Alignment Review Orientation always centers about 0,0.
• Memory Leaks in Registration with certain data sets.
• 2.5d shows the real view of previous scan sometimes.
• Survey Alignment Change doesn’t create/update Survey Report.
ReCap 1.2 New features/functionalities:
• Integrate Autodesk Meta license and provide 30 days trial.
• DeCap: Major functionality of ReCap Pro via a command-line interface. Internal and external partners will be able to leverage ReCap Pro functionality through a simple, high-level interface without needing to use the native user interface.
• Users can queue up registration results, allowing them to make progress on the next scan while the scan refinement runs in the background.
• Final registration view update.
• Allows the user to return to the registration environment to review/edit/add survey points or remove scans from the project.
• Expose new preferences for ReCap projects that will allow Users to specify unit type, decimal precision; Modify how coordinate prefixes appear in the program (XYZ); Designate automatic simplification if a unit value is too big or too small for the specified unit (i.e. display 1000mm as 1 m)
• Expose a small coordinate display in the bottom left corner of the ReCap window.
• User interface improvements.
• Drag and drop files from Windows Explorer to ReCap to process.
• Support Faro 5.2 scan version.
ReCap 1.2 Major Bug fixes:
• Cancel creating project is slow.
• Fix crash during export when indexing is in progress.
• Fix Crash when switching to real view after skip registration when some scans are still indexing
• Indexing conflict with publishing to 360.
• Cannot return to 3D view after clicking "home" button during indexing
• Auto setting with Max Memory setting.
• Exporting failure of unstructured data when set unify spacing as 0mm.
• Reopen a suspended project doesn’t enter import workflow.
• Recap freezes when survey points are created near border and survey UI is off screen.
• Indexing Freeze if Temp Files don't exist.
• Region will disappear after dragging mouse from blank area to cover it in Project Navigator.
• Text label on gradient ramp is cut off when range is too large
• Fail to publish sometimes.
• Fail to publish files if project name contains special characters.
• Crash to suspend import during registration.
• Crash when remove scan from add file view during register queuing.
• Publishing fails with large number of scans.
• Performance issue when combining multiple projects.
• Indexing large PTX file never completes.
• Recent Projects shouldn't appear when it’s removed.
• For some scan types (PTX specifically) the RGB and Intensity are not correctly set during index.
• Duplicate system gradients when edited.
• Crash during rcc generation for special ptx files.
ReCap 1.1 Hot fix:
• Crash while trying to align two rcp files
• Scanorama is not refreshed when clicking other mirror ball or scan location once user has clicked the current mirror ball or current scan in PN.
• Same file can be added to the importing list sometimes.
• Thumbnail progress will be broken when removing a scan from add import file page
• Only first file is added to importing list for some fws file.
• Crash when register two rcp files which has more than one group during creation.
• Quick crash or export failed when exporting structured files.
0 REPLIES 0
Rail Community
