ReCap Pro General
Message 1 of 13 (623 Views)
ReCap Pro Installation
623 Views, 12 Replies
08-08-2013 09:15 AM
While installing ReCap pro trial it encountered an error immediately with install the 2008 C++ Redistributable. It turns out the error was that it was not included with the extracted files.
Copied the file from a different installation and added it in a the correct path. Installed with no errors.
Member
Message 2 of 13 (505 Views)
Re: ReCap Pro Installation
09-10-2013 05:58 AM in reply to: rjay75
Thanks, this worked for me too! Finally got it to install properly:smileyhappy:
New Member
Message 3 of 13 (459 Views)
09-24-2013 08:18 AM in reply to: rjay75
Having the same problem, could you elaborate on the solution?  Is it just downloading the C++ 2008 Redistributable from Microsoft?
Member
Message 4 of 13 (448 Views)
09-25-2013 02:22 AM in reply to: rjay75
In the error message the installer specifies which VC redistributable it wants to install and where it is looking for it. When I checked that path it turned out both the folder and VC redist. was missing, so i created the requested folder and downloaded the correct VC redist. (in my case I think it was the 2010 service release 1 x86) from microsoft to the folder I had created. Ran the installer again (directly from the c:\\Autodesk folder where the files had been unpacked) and everything went smoothly. Hope this helps.
Member
Message 5 of 13 (343 Views)
10-16-2013 09:40 AM in reply to: tronmikk
I can't believe this hasn't been fixed..  I spent a large amount of time trying to get Recap Pro to install.  I would think a new download file would be released with the correct files for install.
Distinguished Contributor
Message 6 of 13 (333 Views)
10-17-2013 06:52 AM in reply to: smetzger
I've been jerking around with this for a week.  I'll attempt to unravel the explanation and make it work.  It's insane that we have to go through this.  Not very VIP or customer oriented. A bulletin and detailed guideline from AutoDesk would be nice.
Message 7 of 13 (325 Views)
10-17-2013 07:30 AM in reply to: tronmikk
On the initial failed install, the log listed "C:\Autodesk\yada\yada\yada\2008SP1\vcredist_X86.exe" as failing.  I created this directory, put in the file, ran the install and got 30 seconds on ReCap install spash screens.  While I was yoohooing, it failed again.  This time it askes for  "C:\Autodesk\yada\yada\yada\2010SP1\vcredist_X86.exe".
As you can see in thre attached, I have in in there.  Still won't install.
What is going on here?
Message 8 of 13 (316 Views)
10-17-2013 07:54 AM in reply to: buckdog
I got it working on a different computer.  Slower.  Better than nothing.
New Member
Message 9 of 13 (301 Views)
10-17-2013 01:04 PM in reply to: rjay75
If you go to the microsoft website or google search these two programs:
Microsoft C++ Redistributable 2008 (x86) SP1
Microsoft C++ Redistributable 2010 (x86) SP1
Then download and install them, the program will finally install.  I have no idea why Autodesk hasn't included these files in the installer.  Pretty big oversight.
Message 10 of 13 (292 Views)
10-17-2013 01:31 PM in reply to: buckdog
The error message 1603 with it is a generic error that could be a lot of things.
As JeffT said. Try redownloading it from MS site and installing it manually on the machine it's failing on.
I would still copy it to the missing folder as well.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
