How come there is no export to .RCS?
This seems like a fairly logical format to be able to do so.
Solved by catherineliu. Go to Solution.
Hi Chad,
We provided the option to export to RCS in SP1. Have you installed the service pack?
Catherine
Bazar,
This thread is over a year old. Are you looking for the latest update? ReCap updates will show up in your Autodesk Applications Manager.
If you need to download the latest installer directly, you can do so from here: http://www.autodesk.com/products/recap/free-trial
(The 'trial' is the full installer. ReCap updates are free so you can update even if you have a much older version.)
did you find an answer to your problem? I'm having the same issues.
thanks,
Hello from Spain.
When Recap creates a new project, an associated folder is created too. In this folder you can get the rcs files directly. Its not needed exporting..
These rcs files can be loaded directly in ReCap, keeping the realview information.
Regards
