ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Putting clouds together
2 REPLIES 2
Light_Guy
555 Views, 2 Replies
We are currently working a study about we can best use reality capture in our business. One thing that has popped up is putting data together from different types of scanners. We have been using laser scanners from Faro and Leica with great success but then we also tried to use the Microsoft Kinect. When have been unable to put the cloud from the kinect together with clouds from the Leica and Faro scanners. My understanding is that because it is Infrared versus laser there is no way to put the two together using ReCap. Is this true? We recently saw the new DPI-7 handheld scan to tablet scanner which I believe is also infrared. Would I be in the same boat with this scanner as well?
Paul Hamor
"Always good ships!"
2 REPLIES 2
vidanom
in reply to: Light_Guy
Hi Paul,
It depends on the way the app is writing the data when using the Kinnect or Asus sensor.
ReCap can only align structured data, fls, ptx, ptg or zfs file formats.
If the data is written in such way and one of this file formats is available then ReCap can be used for aligning these scans with other Terrestrial scanners.
I attached one document describing the simple process of aligning such scans using the DOT handheld device with Faro Focus 3D scanner:
http://www.dotproduct3d.com/
Thank you for posting,
Best,
Mitko
Light_Guy
in reply to: vidanom
Mitko,
That's excellent news! Thanks for the info, I am passing the help file you sent on to our study group. We really appreciate it!!
Paul Hamor
Rail Community
