In AutoCAD there is an option to do a "linear dimension" then to go back aftward and edit just the dimension numeral (text) to relocate just the number anywhere you desire.
In my QC8 the format option lets me set the numeral orientation,(None, Text in, Text above, & Text below) Is there a way in QC8 to relocate only the dimension number, after a dimension line has been defined.
I can explode the linerar dimension and move the numeral and then re-group but I loose the linear dimension properties and the dimension becomes just an entity.
I would like to keep the dimension set-up as a linear dimension but have the option to freely move the numeral in relation to the dimension line !!! Is this do-able???
Thanks, Stephen
