• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • QuickCAD
    *Burling, Michael
    dimensioning
    26 Views, 12 Replies
    10-14-1999 09:08 AM
    I have one other problem I haven't been able to figure out.
    I can't find a way to widen dimension and extension lines. They print out
    too faintly.
    Once again, your help would be greatly appreciated.
    Mike
    Please use plain text.
    *Smith, Harvey
    Re: dimensioning
    10-14-1999 11:45 AM in reply to: *Burling, Michael
    Hi, Mike.
    I'll try again, but you know I use AutoSketch.
    The Dimension itself you can change to a bold font by Selecting the dimension,
    choosing Format Dimension from the Edit bar, and the Label tab. Or you can Right
    click on the Selected dimension and choose Format Dimension from the pop-up
    menu.
    Dim and ext lines have no separate command for line thickness, as far as I know.
    The only way to get to these is to Explode the dimension AFTER you have final
    placement, Select all the dim and ext lines (hold the [Shift] ket while
    selecting), Right click and choose Entities. In the Width drop-down box you can
    choose any of about 5 or 6 line thicknesses. Hopefully one of these will suit
    you. I suppose you could change them all to polylines with the Trim Subdivide
    command. That way you get infinite line thickness choices from the Edit bar. But
    that seems awfully tedious.
    Harvey
    > too faintly.
    > Mike
    *Rafuse, L.
    Re: dimensioning
    10-14-1999 02:34 PM in reply to: *Burling, Michael
    > too faintly.
    > Mike
    You could explode all of them then select all lines and increase the width
    before plotting.
    Len Rafuse
    Vision Engineering
    *Smith, Harvey
    Re:
    10-14-1999 02:41 PM in reply to: *Burling, Michael
    Hi, Len.
    > > too faintly.
    > > Mike
    > before plotting.
    > Len Rafuse
    > Vision Engineering
    It's too bad you can't choose Line Thickness from the Edit bar if you Select
    *all* the lines (with the Shift key). You're limited to the five preset
    thicknesses in the Entities>General tab.
    This would seem to be a useful addition to future revs, no? I'm surprised this
    issue hasn't shown up more.
    H
    *Rafuse, L.
    Re:
    10-14-1999 03:09 PM in reply to: *Burling, Michael
    Anybody who sticks with it finds a work around that is passable. Having the old
    Drafix Pro with macros allows me to quickly "thicken" a drawing for plotting.
    Without my macros I may have ended up in a different CAD group.
    Len Rafuse
    Vision Engineering
    Harvey Smith wrote:
    > Hi, Len.
    > > > too faintly.
    > > > Mike
    > > before plotting.
    > > Len Rafuse
    > > Vision Engineering
    > H
    *Smith, Harvey
    Re:
    10-14-1999 03:49 PM in reply to: *Burling, Michael
    Len.
    Something I've been meaning to ask you. How do you get a macro, written for a
    different package, to work with your current cad software?
    Does this question show my ignorance of what these macros are? You don't have to
    answer that one, please.
    H
    > Len Rafuse
    > Vision Engineering
    > Harvey Smith wrote:
    > > Hi, Len.
    > > > > too faintly.
    > > > > Mike
    > > > before plotting.
    > > > Len Rafuse
    > > > Vision Engineering
    > > H
    http://www.westnet.com/~harvey/
    *Jackson, Paul
    Re: dimensioning
    10-14-1999 06:19 PM in reply to: *Burling, Michael
    Hello Michael
    Try reducing the resolution of your printer. I like to use 300DPI.
    Paul Jackson
    Michael Burling wrote in message <7u4vbu$2b41@adesknews2.autodesk.com>...
    >too faintly.
    >Mike
    *Burling, Michael
    Re:
    10-14-1999 10:25 PM in reply to: *Burling, Michael
    Hi, Harvey
    dimension,
    Right
    pop-up
    > menu.
    I can get the dimension itself dark enough.
    know.
    final
    you can
    suit
    Subdivide
    bar. But
    I did as you suggested. After choosing Entities, the "Edit Entities" box
    opens, and in the "layer & pen" section, there is a layer, color, style, and
    width drop-down box with width options from 1 to 9. None of these will
    change anything (monitor or printer)except for the color (thin red or yellow
    lines look funny).
    Would anyone know if there is a patch for QuickCad v 4.12 to fix this, or if
    reinstalling would fix this feature or am I just missing something?
    I could be missing one thing. I don't know what you mean by "Explode the
    dimension" and I can't find a definition for "Explode."
    Also, as Paul Jackson suggested, I already have my printer set at 300 DPI.
    Mike
    *Rafuse, L.
    Re:
    10-15-1999 05:49 AM in reply to: *Burling, Michael
    Harvey Smith wrote:
    Len.
    for a
    have to
    H
    I save all of my files in the older Drafix format with the CAD extension.
    I can then open the files in Drafix Pro and run the macro there.
    Since AutoSketch 6.0 is based on Drafix the files can go back and forth
    fairly seamlessly so long as you avoid certain features.  Of course
    I need to avoid most those features anyway to ensure that my files transfer
    to my customers.
    I unfortunately have not found a way to use the old macros directly
    in the new AutoSketch.  My hope is that version 7 will solve this
    problem.
    Len Rafuse
    Vision Engineering
    *Rafuse, L.
    Re:
    10-15-1999 05:52 AM in reply to: *Burling, Michael
    Explode is listed as "convert to base entities" on older versions. It will turn
    the dimension into lines that can then have their thickness increased.
    Len Rafuse
    Vision Engineering
