QuickCAD
Member
r.piras
Message 1 of 34 (2,002 Views)
convert drafix .cad
2002 Views, 33 Replies
05-18-2004 07:10 AM
hi all
i got a really big problem that needs a solution.
in the far 1993 i drawed something with drafix windows cad and (shame on me) saved it in the *.cad-format.
is maybe anybody from you able to convert this files into a normal format like *.dxf?
would be very kind if there is a workaround for this
regards
renato // cologne
fozzie99
Message 2 of 34 (2,002 Views)
Re: convert drafix .cad
05-26-2004 09:48 AM in reply to: r.piras
How large is the file?? I still have a copy of that old program and If it is something you can send to me I may be able to do the conversion to either .dxf windows meta-file or AutoCAD.. But beware there are some inherent problems in doing conversions out of the .CAD format depending on what you drew and how you drew it....
New Member
daveg
Message 3 of 34 (2,002 Views)
03-16-2005 11:03 AM in reply to: r.piras
I noticed you mentioned you had a old copy of Drafix. I'm looking to open a bunch of old files (saved in Drafix proprietary .DXG format) using Drafix 1.0 (maybe 2.0). Would you be willing to share a copy of your old program so I can recover some data. I could destroy it after.
Thanks for whatever help you may provide.
daveg@intermec.com
New Member
JIGGS1937
Message 4 of 34 (2,002 Views)
06-30-2005 02:33 PM in reply to: r.piras
I HAVE SEVERAL VERSIONS OF THE ORIGINAL VERSION OF DRAFIX , ALSO WINDOWS VERSION FOR WINDOWS 3.11. IF YOU HAVE NOT CONVERTED YOUR FILE YET MAYBE I WILL BE ABLE TO HELP YOU.
I WOULD LIKE TO PURCHASE A WINDOWS DISK OF DRAFIX FOR 95 WINDOWS. IF YOU HAVE ONE OR KNOW OF ONE LET ME HEAR.
New Member
t.bura
Message 5 of 34 (2,002 Views)
11-16-2005 09:15 AM in reply to: r.piras
I noticed on a posting that you had several older versions on Drafix. Might you be willing to part with any of them. I also have several versions going back to 3.0 for windows 3.1, but they don't run on newer machines. I have a group of drawings that were created in Cadultra and saved in .dwg format. Whenever you open them in the new verson(Quickcad) a bunch of the attributes, including the font on dimensions, changes. The only way I've been able to get around it is to open the drawing, manually change everything that needs changing, then save it in a new format, .cad. Problem is, I have, ';m guessing here, 1000 drawings.
New Member
t.bura
Message 6 of 34 (2,002 Views)
11-17-2005 06:12 AM in reply to: r.piras
DO you still have any old copies of Drafix? Might you be willing to part with any?
New Member
mlloyd
Message 7 of 34 (2,002 Views)
02-18-2006 10:04 PM in reply to: r.piras
I am looking for a Drafix CAD 2.1 to convert some very old files. Any chance of getting a copy or do you know where I might get a copy? ML
New Member
mlloyd
Message 8 of 34 (2,002 Views)
02-19-2006 12:16 AM in reply to: r.piras
I am looking for drafix cad 2.1 to open some old files. Any chance you might have a copy of know where I might locate a copy?
New Member
swtwomyn
Message 9 of 34 (2,002 Views)
04-12-2006 07:55 AM in reply to: r.piras
i have some .CAD files on a CD from a customer, do you have a program that opens them? I just need to open and print them. I can't find a viewer or program to view and print. Can you help? I tried to attach an example but it says content type not allowed. Thanks for any help! Tracy
*Harvey
Message 10 of 34 (2,002 Views)
04-12-2006 11:59 AM in reply to: r.piras
Zip up the file and send it to the group that way.
You're accessing the newsgroup from the net side,
not NNTP.
You can try adding the newsgroup to your
mailer/newsgroup reader, (like Thunderbird, OE,
others) and see if you can upload the file that way.
H
You are not logged in.
Ask the Community
