• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *Cronham, Chip
    Type Text but nothing appears on drawing
    40 Views, 8 Replies
    03-02-2000 03:56 PM
    Did the following nothing happened, except an empty box appeared:
    1 Clicked on text button
    2 Made sure formula was not checked
    3 Clicked a point for base point
    4 Entered text
    5 Clicked ok- - -no text
    If I right click on frame, text editor appears with text in it but it does
    not display on sheet.
    Please use plain text.
    *Brinsden, Marcus
    Re: Type Text but nothing appears on drawing
    03-02-2000 05:42 PM in reply to: *Cronham, Chip
    Select View>Options>Visibility and tick the text option.
    Chip Cronham wrote in message
    news:89mv5d$hhj21@adesknews2.autodesk.com...
    > 4 Entered text
    *Smith, Harvey
    Re:
    03-02-2000 06:19 PM in reply to: *Cronham, Chip
    Marcus,
    I presume there is an view option in QC to make text visible. Why is
    there such a thing? When would you want to make your text invisible?
    There doesn't seem to be such a thing in AS.
    H
    *Brinsden, Marcus
    Re:
    03-02-2000 06:55 PM in reply to: *Cronham, Chip
    I have no idea. There are a lot of settings that seem to have no apparent
    use like the 'Protect Layer Changes' setting in the Layer Properties dialog
    box.
    Paul is on holiday for 2 weeks so your going to have to put up with me until
    he gets back!
    Harvey Smith wrote in message
    news:38BF213E.EA55B17E@westnet.com...
    > Marcus,
    > H
    *Norris, Ric
    03-02-2000 11:00 PM in reply to: *Cronham, Chip
    Hi Chip,
    Have you checked the size of the font....it might be very small....hence why
    you can't see it on screen but can see it in the text editor window.
    Ric Norris.
    "Chip Cronham" wrote in message
    > 4 Entered text
    *Smith, Harvey
    Re:
    03-03-2000 07:04 AM in reply to: *Cronham, Chip
    I know that Paul has been on about that in the past, and I think that
    opinion turns up in his book, also. And if YOU guys don't know why
    that's there, it probably is some artifact from an early version
    (preDrafix?) that has no use now. It actually can confuse things. Do you
    know of other weirdnesses like that lurking to bite us?
    BTW, no problem about putting up with you. You actually write complete,
    intelligent sentences that I can understand. As opposed to the croc.
    Hope his demeanor is more pleasant when he returns.
    H
    > box.
    > he gets back!
    > > Marcus,
    > > H
    http://www.westnet.com/~harvey/
    *Crowe, Robert
    Re:
    03-04-2000 04:03 AM in reply to: *Cronham, Chip
    I bought QuickCad 7 about a month ago and have been delighted with the
    features compared with AutoCad 8 I used before I retired 8 years ago.
    One problem: sometimes when I 'hatch' an area, the text in the area
    disappears. I saw your suggestion to try 'View, Options, Visibility,
    Text" but the Options page doesn't have Visibility that I can see and
    the only text reference is to make the text reference tick visible or
    not. I've tried manipulating the layers: same layer, different layers,
    etc. If I make the hatch layer Background, the text reappears, but then
    when I 'Copy' and try to put it in a document, the Hatch doesn't
    transfer. What am I missing?
    *Smith, Harvey
    Re:
    03-04-2000 01:10 PM in reply to: *Cronham, Chip
    Robert,
    Try selecting the hatch and typing [Ctrl]+B which should send it to
    background. That's the way it might work in AutoSketch.
    When you Copy to a document, try PasteSpecial.
    H
    *Becker, Don
    Re:
    03-20-2000 06:55 AM in reply to: *Cronham, Chip
    No text display is a good option for users with large files that don't need
    to see the text,
    if you turn it off, the computer doesn't have to reload it, giving faster
    reload times.
    -Don Becker
    news:38BFD46A.47D2CB65@westnet.com...
    > H
    apparent
    dialog
    > > box.
    until
    > > he gets back!
    > > > Marcus,
    > > > H
