• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *Swaim, John
    Traffic accident diagrams
    93 Views, 4 Replies
    01-29-2000 10:48 AM
    I've recently begun using Quickcad 7 for traffic accident diagrams. It seems
    to be a good program for job. However, we have a specific page to print the
    diagrams onto. The problem I've run into is when I have a multiple page
    diagram to do. When I print onto the second page, the diagram prints in the
    predefined margin area of the paper. There is certain information that is
    already pprinted on the top and bottom section of the page. having the
    diagram print over this information does not look professional. Is there a
    way around this problem?
    Please use plain text.
    *Support, Autodesk
    Re: Traffic accident diagrams
    04-27-2001 07:57 AM in reply to: *Swaim, John
    John;
    QuickCAD prints using the parameters assigned in the windows printer
    driver.
    There is no true way to force something to print the way you need it to
    in QuickCAD other than seperating the different pages into seperate
    drawing files and printing each one at a time.
    > seems
    > print the
    > page
    > in the
    > is
    > there a
    *Higginbottom, Barry
    04-27-2001 08:33 PM in reply to: *Swaim, John
    ------=_NextPart_001_000E_01C0CFD7.028717A0
    Content-Type: text/plain;
    charset="iso-8859-1"
    Content-Transfer-Encoding: quoted-printable
    John
    If your original drawing is drawn to scale on the sheet size of your =
    report, e.g. 8.5" x 11" then to print specific areas adust the margin =
    settings to restrict the print area to the bit you want. With QC7 this =
    is quite easy to do from the print preview window. If you want to print =
    the whole drawing (not to scale) in a small window on the page then just =
    adjusts the margins to suit the size and position of your 'window', =
    select "Fitted to Printer Page" and "Extents View"other than "Scaled" =
    and "Page View".
    I am sure that with a bit of judicious margin adjustment prior to each =
    print job you can achieve exactly what you want.
    Sorry about the inserted pictures but I felt a picture was worth a =
    thousand words in this instance!
    Good luck!
    Barry Higginbottom
    Kentra Grain Systems Limited
    YORK, England
    http://www.graindriers.com
    "John Swaim" wrote in message =
    news:86vf7d$cq8@adesknews2.autodesk.com...
    I've recently begun using Quickcad 7 for traffic accident diagrams. It =
    seems
    to be a good program for job. However, we have a specific page to =
    print the
    diagrams onto. The problem I've run into is when I have a multiple =
    page
    diagram to do. When I print onto the second page, the diagram prints =
    in the
    predefined margin area of the paper. There is certain information that =
    is
    diagram print over this information does not look professional. Is =
    there a
    Content-Type: text/html;
    charset=3Diso-8859-1">
    John
    If your original drawing is drawn to scale on the =
    sheet size=20
    of your report, e.g. 8.5" x 11" then to print specific areas adust the =
    margin=20
    is quite=20
    easy to do from the print preview window. If you want to print the whole =
    drawing=20
    (not to scale) in a small window on the page then just adjusts the =
    margins=20
    to suit the size and position of your 'window', select "Fitted to =
    Printer Page"=20
    and "Extents View"other than "Scaled" and "Page View".
    I am sure that with a bit of judicious margin =
    adjustment prior=20
    to each print job you can achieve exactly what you want.
    3D"" src=3D"cid:000701c0cfce$a0766460$0100007f@office1" align=3Dbaseline=20
    border=3D0>
    3D"" src=3D"cid:000801c0cfce$a07f8c20$0100007f@office1" align=3Dbaseline=20
    border=3D0>
    Sorry about the inserted pictures but I felt a =
    picture was=20
    worth a thousand words in this instance!
    Good luck!
    Barry Higginbottom
    YORK, England
    style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
    BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    I've=20
    seems
    to=20
    be a good program for job. However, we have a specific page to print=20
    the
    diagrams onto. The problem I've run into is when I have a =
    multiple=20
    page
    diagram to do. When I print onto the second page, the diagram =
    prints=20
    in the
    predefined margin area of the paper. There is certain =
    information=20
    that is
    already pprinted on the top and bottom section of the page. =
    having=20
    the
    diagram print over this information does not look professional. =
    Is=20
    there a
    ------=_NextPart_001_000E_01C0CFD7.028717A0--
    *Harvey
    Re:
    04-28-2001 12:40 AM in reply to: *Swaim, John
    Barry,
    Just some advice, and it may be worth what you're paying for it.
    You shouldn't post to the Newsgroup in HTML. Lots of folks don't have
    readers or browsers that support it and your comments will be lost.
    You shouldn't post files here as binaries in general. They oughta go in
    the Customer Files area, at least for now. I, for one, cannot even open
    the files with the Netscape 4.75 browser. I guess I'll have to get 4.77.
    But the files may have been corrupted somehow.
    Re:
    I know, I know! :smileyembarrassed:)
    Hence my last line of apology, after I had pressed the send button I knew
    I'd goofed so I emailed my reply direct to John. I should have done so first
    time.
    A zillion apologies.
    Barry
    "Harvey" wrote in message
    news:3AEAD645.CBDD5E60@westnet.com...
    > Barry,
