• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *Criss, Henry
    QuickCAD Newbe with Problems
    23 Views, 5 Replies
    03-21-2000 06:53 PM
    I an new to CAD have had QuickCAD for a couples weeks now. I was
    fortunate enough to have run across this news group and I thought this
    group might help me with. I have been trying to draw Isometric drawings
    of pipe and have run into several problems.
    Problem #1: When I try to place dimensions on my isometric drawing the
    lines do not take the same angle as the ISO, rather the end up with the
    at an odd angel not suitable for Isometrics'. Is there some way to set
    the dimensioning lines to match the ISO.
    Problem 2 and 3 are problems that appear to be bugs.
    #2 Sometime when I try to save a drawing I get a QuickCAD dialog box
    with a big red "X" that says "Invalid dialog box procedure return code."
    and I can not save the DWG. I have to Exit QuickCAD and then restart the
    program.
    #3 Sometime after immediately after exiting QuickCAD I get a Windows
    Dialog box with a big red "X" that says " This program has performed an
    illegal operation and will be shut down. The detail box information says
    Explorer caused an invalid page fault in module < unknown > at
    0000:00c657cd. This only happens after existing QuickCAD.
    Has anyone else experienced these type of crashes? Any help would be
    appreciated .
    Henry Criss
    hcriss@earthlink.net
    Please use plain text.
    *Smith, Harvey
    Re: QuickCAD Newbe with Problems
    03-21-2000 07:08 PM in reply to: *Criss, Henry
    Henry,
    I can only address Problem#1. Try placing the dimension in normal 2D mode and
    convert both the dimension and the drawing to isometric view together.
    I think also if you use a TT font for any text, that will convert to isometric
    nicely, too.
    About the other problems, wait for the pros.
    H
    *Smith, Harvey
    03-21-2000 07:29 PM in reply to: *Criss, Henry
    Henry,
    If you REALLY want the dimensions to line up properly in an iso view, you have
    to
    1. choose a TT font for the text (dimension). NOT cad font
    2. place the dimension in the normal 2D drawing
    3. Explode the dimension (Select and choose Explode)
    4. Convert the text to polygons (Select text only, rightclick and convert)
    5. Convert both the drawing part PLUS the entire dimension at the same time to
    the iso view
    6. Select text again and fill it from the Property toolbar with the color of
    your choice.
    That's how I would do it in AutoSketch. See if it works for you in QC.
    Then you can wonder why a person would do such a thing. You'd think it would be
    easier. Imagine doing that to an entire drawing.
    Well, maybe a smarter-alec will come up with a short cut. I never found one.
    About Problems#2 and #3, you'll have to wait for a pro.
    H
    *Support], Keith Sibbert [Autodesk
    03-21-2000 09:41 PM in reply to: *Criss, Henry
    Henry,
    The error messages in #2 and 3 sound like an operating system problem. I
    would strongly urge you to contact Microsoft's tech support on this. At the
    very least, check their online knowledge base and see what it might have.
    Keith Sibbert
    PSG Product Support, Americas
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    > program.
    > appreciated .
    > Henry Criss
    *Criss, Henry
    Re:
    03-22-2000 04:16 AM in reply to: *Criss, Henry
    In article <38D85CFD.410E566B@autodesk.com>,
    discussion.support@autodesk.com says...
    > Keith
    Thank you Keith, for your prompt reply. As you have suggested, the
    problem may well be an operating system problem but it only happens when
    QuickCAD is running or has been run. I have not had this problem when
    running other CAD software. (such as TurboCad or AutoCAD) nor when
    running any other application programs. That leads me to believe there is
    a conflict somewhere between QuickCAD and my operating system, which by
    the way is Windows 95. (more on my system blow)
    Machine
    Packard Bell Synera
    Cyrix M II 266 MHz
    48 Mb RAM
    4 Gig HD
    Windows 95
    Henry Criss
    Re:
    03-23-2000 08:03 AM in reply to: *Criss, Henry
    The only thing I can suggest is to try uninstalling and reinstall QuickCad.
    Which version of Win95 do you have (Start>Settings>Control
    Panel>System>General tab)?
    Keith Sibbert
    > > Keith
    > Machine
    > Packard Bell Synera
    > Cyrix M II 266 MHz
    > 48 Mb RAM
    > 4 Gig HD
    > Windows 95
    > Regards,
    > Henry Criss
