QuickCAD
*Hulbert, Rod
Message 1 of 3 (29 Views)
QC R7 shift +/-
29 Views, 2 Replies
02-18-2000 11:09 PM
As a former Drafix Cad Pro user I normally center and zoom on a
selected object by doing [NUM Lock(off)] [Shift]&
[(numberpad)+/-]. This works in QC 7 but it also rotates the
object. Could someone check this? I'd like to know if its QC or
QC and my computer setup that's broke.
thanks
Rod
*Norris, Ric
Message 2 of 3 (29 Views)
Re: QC R7 shift +/-
02-19-2000 12:53 AM in reply to: *Hulbert, Rod
Hi Rod,
No.....your computer ain't broke.
If you select an object, +/- will rotate the object at the angle as defined
in Drawing Options....regardless if Num Lock is ON or OFF.
Shift +/- will rotate & zoom if Num Lock is OFF and rotate only if Num Lock
is ON.
Ctrl +/- will zoom only....regardless if Num Lock is ON or OFF.
The same applies in QC V6 & AS R7.
Ric Norris.
"Rod Hulbert" wrote in message
news:88lfh9$c2t30@adesknews2.autodesk.com...
> thanks
> Rod
*Smith, Harvey
Message 3 of 3 (28 Views)
Re: QC R7 shift +/-
02-19-2000 07:08 AM in reply to: *Hulbert, Rod
Hey, Rod,
In AutoSketch, you can type Ctrl+ to view the entire drawing. Select a
portion of it, and Ctrl+ fills the screen with the selection set. Does it
work that way in QC?
Try the Help file. In the Index Field, type "Keyboard" and see what's available
as shortcuts.
H
> thanks
> Rod
http://www.westnet.com/~harvey/
You are not logged in.
Announcements
Need installation help?
Ask the Community
