• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *lowery, Dwayne
    Printing grid points
    30 Views, 2 Replies
    10-07-1999 06:42 AM
    Is there any way to print the grid to paper? Can I print the grid as points?
    Help!!!! Dwayne
    Please use plain text.
    *Support, Autodesk
    Re: Printing grid points
    10-07-1999 11:42 AM in reply to: *lowery, Dwayne
    Dwayne,
    The grid that displays is a background drawing reference only and cannot be
    printed. The only way I know to print a "grid" is to create the grid using array
    then print it.
    Keith Sibbert
    PSG Product Support, Americas
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    > Help!!!! Dwayne
    *Smith, Harvey
    10-10-1999 01:49 PM in reply to: *lowery, Dwayne
    Dwayne.
    You can do both of those things. Keith suggested the Array tool, which I agree
    with. Create a rectangle with the grid dimensions you need. Use the 2D
    Coordinate box for that. Start drawing the rectangle and type and the dialog
    box will appear. Type the grid values in (use tab to toggle) and hit Enter.
    Close with a Snap. Select the rectangle and choose the Rectangular Array tool.
    Put in the appropriate values and you got it.
    To make points, you'll have to use small circles, and then the Rectangular Array
    tool. Same as above.
    Harvey
    > Help!!!! Dwayne
    http://www.westnet.com/~harvey/
