• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *Budd, Tom
    PLOTTER DRIVERS-Summagraphics or Houston Instruments drivers for V6?
    195 Views, 1 Replies
    02-15-2000 01:29 PM
    Does anyone know if there are plotter drivers available for Older Houston
    Instruments or Summagraphic plotters for use with Quickcad V6? I have been
    using Quickcad v 3.02 with an older Houston Instruments Pen Plotter (DMP-60)
    with a driver (I believe from Summagraphics) ver. 2.40 without a problem.
    I installed v6 but the plotter driver does not seem to work properly with
    the new version of Quickcad. TMS Plotter Specialists lists a driver for
    Windows 95/98 which they say is not compitable with AutoCAD 2000. Are
    quickcad v6 and Autocad 2000 similiar enough where the driver would not be
    considered compatible? Or could I use another driver that may be compatable
    with Autocad 2000? Does anyone know where I can find drivers?
    Any help, comments, suggestions would be appreciated.
    Tom Budd
    tbudd@sight-pipe.com
    Please use plain text.
    *Support], Keith Sibbert [Autodesk
    Re: PLOTTER DRIVERS-Summagraphics or Houston Instruments drivers for V6?
    02-15-2000 10:22 PM in reply to: *Budd, Tom
    Tom,
    You might check at http://www.cadalog.com/ or at http://www.winline.com/ and see
    if they have a Windows system driver that will work for your plotter.
    Keith Sibbert
    PSG Product Support, Americas
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    > Tom Budd
