• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *Rowen, Bob
    Freeze on opening .dwg with QC7
    23 Views, 3 Replies
    02-29-2000 04:53 PM
    I just obtained QuickCAD to work with several architects' dwg files.
    The first one freezes on the "Open Shape File" dialog box.
    The dwg file is about 300k, shows beautifully in the Preview window and
    opens fine in NS with Vdraft.
    Any suggestions appreciated.
    By the way, are there sources for architecctual symbols other than the
    Autodesk CD?
    Robert Rowen
    Library Automation Management, Inc.
    101 Clark Street, 27C
    Brooklyn Heights, NY 11201
    (718) 834-1414
    Our Web Site is: libraryautomation.com
    Our E-Mail Address is mail@libraryautomation.com
    Fax: (718) 222-4946
    Please use plain text.
    *Support], Keith Sibbert [Autodesk
    Re: Freeze on opening .dwg with QC7
    03-02-2000 10:40 PM in reply to: *Rowen, Bob
    Bob,
    My guess would be that the drawing has 3D objects in it and QuickCad
    doesn't do 3D. If you flatten the drawing file, you should be able to open
    it with no problems. The preview displays fine because it is a small
    bitmap that is attached to the drawing file.
    > Autodesk CD?
    > Robert Rowen
    > (718) 834-1414
    > Fax: (718) 222-4946
    Keith Sibbert
    PSG Product Support, Americas
    WW Support & Services, Autodesk
    Discussion Q&A: http://www.autodesk.com/discussion
    *Rowen, Bob
    Re:
    03-03-2000 08:39 PM in reply to: *Rowen, Bob
    Keith,
    How do you flatten it before opening
    it?
    Actually, the name of the Open Shape File it hung up on was Archstyl.shx;
    I found it and put it in QuickCAD's Properties subdirectory and then it
    opened fine, with notice that it was flattening 3D objects.
    "Keith Sibbert [Autodesk Support]" wrote:
    Bob,
    able to open
    a small
    and
    the
    > Autodesk CD?
    > Robert Rowen
    > (718) 834-1414
    > Fax: (718) 222-4946
    Keith Sibbert
    Re:
    03-06-2000 03:28 PM in reply to: *Rowen, Bob
    Bob,
    Flattening would have to be done in AutoCAD before you get the file.
    Sometimes QuickCad has problems in this area but I am glad it's not for
    you and that it was the font file that was the problem.
    Keith Sibbert
    Bob Rowen wrote:
    > Keith,
    > How do you flatten it before opening it?
    > Archstyl.shx; I found it and put it in QuickCAD's Properties
    > subdirectory and then it opened fine, with notice that it was
    >> Bob,
    >> to open
    >> small
    >> files.
    >> window and
    >> the
    >> > Autodesk CD?
    >> > Robert Rowen
    >> > (718) 834-1414
    >> > Fax: (718) 222-4946
    >> Keith Sibbert
