QuickCAD
*Buck, Chris
Message 1 of 4 (54 Views)
Extend line?
54 Views, 3 Replies
01-30-2000 05:07 AM
Can someone tell me please how to extend a line with the mouse. ie. Not
change the orientation but just lengthen.
*Smith, Harvey
Message 2 of 4 (54 Views)
Re: Extend line?
01-30-2000 08:50 AM in reply to: *Buck, Chris
Chris.
Lots of ways. The easiest is to Select it (click on the line) and drag-swipe
across the length field in the Edit Bar so that it changes color. Type in the
length you wish and hit [Enter]. Nothing will change on the drawing until you
hit [Enter] so that the program will accept any change.
H
> Thanks
http://www.westnet.com/~harvey/
*Buck, Chris
Message 3 of 4 (54 Views)
Re:
01-30-2000 03:51 PM in reply to: *Buck, Chris
Thanks for the reply Harvey,
but that is not what I meant. I am just starting to convert over from
TurboSketch and I am used to a command called line length where you can
extend a line with the mouse by dragging on an end. Is there no comparable
command in QC?
Also, if I do as you say then presumbly the line lengthen about its centre
and not at one end?
Harvey Smith wrote in message
news:38946BBB.D27817C0@westnet.com...
> Chris.
drag-swipe
the
you
> H
> > Thanks
*Smith, Harvey
Message 4 of 4 (54 Views)
Re:
01-30-2000 05:32 PM in reply to: *Buck, Chris
Yes there is. Select the line and pull on an end-handle. As you do this, you can
type and input the x/y distance relative from the point you started from.
Another way is to Select, pull the handle, type or , then type in a snap
and pull the line to an object. You can snap with , , , any one of them
that's appropriate.
Lastly, if you lengthen with the 2D coordinate dialog box or the Edit bar, the
line will legnthen from its initial start point - NOT the other way or from the
AboutPoint or the center. The line will continue in the direction you started it
from.
> command in QC?
> and not at one end?
> > Chris.
> drag-swipe
> the
> you
> > H
> > > Thanks
You are not logged in.
Announcements
Need installation help?
Ask the Community
