• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *Clark, Christopher
    Drafix cad Ultra
    1037 Views, 4 Replies
    03-17-2000 06:05 AM
    Can Quickcad load Drafix Ultra files? I have older
    drawings that
    I would like to convert to DXF. Ultra will not run
    on my newer PC.
    Is there a program for DWG->DXF somewhere on the
    net?
    Thanks in advance.
    Please use plain text.
    *Maugeri, Ralph
    Re: Drafix cad Ultra
    03-20-2000 06:59 AM in reply to: *Clark, Christopher
    I'm new here, but your question remains unanswered, sooo....
    I haven't tried to bring ultra drawing to Qcad. But you may have to
    bring them into drafix cad and then into Q-cad.
    Bringing them into D-cad was messy. Have you tried going to dos and
    running ultra, or are you running 2000?
    Have fun.
    Ralph Maugeri
    Creative Arch. Designs.
    *Clark, Christopher
    Re:
    03-30-2000 10:45 AM in reply to: *Clark, Christopher
    Thanks for the Help. I managed to run ultra in a DOS window (W98) by
    renaming
    a video driver. ( old ones were HALO drivers). Anyways, I could see only 1/4
    of the screen
    and ran my commands via the keyboard.
    From AutoCAD LT98. Do a file recover, type *.DXF.
    This worked well and preserved all the SYMBOLS/BLOCKS.
    After, Just do a save as...
    New Member
    Re: Drafix cad conversion
    05-08-2012 05:44 PM in reply to: *Clark, Christopher
    Hola!
    I have hundreds of drawings on old Drafix from the 80s.
    It is based on Halo and runs only on DOS.
    I can run it in the DOS shell of Windows XP, but it expects to output to LPT1 or a Com port.
    And it has a limited list of printers it can drive including HP Inkjet and "Inkjet+ /2"
    The HP672C I relied on is now a coffee grinder that I probably can't get repaired or replaced.
    Only their lasers have parallel ports.
    Any ideas?
    Centronics to USB conversion to recent HP Inkjet?
    Method transferring/converting .dfx files to another format?
    New Member
    Getting old Drafix files
    05-08-2012 05:47 PM in reply to: *Clark, Christopher
    Saw your post.
    Have classic Drafix from the 80s and hundreds of files for it and the HP672C on which I relied is grinding coffee.
    Drafix wants to use LPT1 or a COM port and drive an HP Inkjet or similar old device
    Can I take .dfx files and convert them to/in a program I have more printing options on?
