• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    New Member
    Converting from Corel CDR to DXF
    704 Views, 1 Replies
    06-08-2007 08:49 AM
    I am working with Win2k version of Corel 9 CDR format and trying to convert to a DXF to be used in QuickCAD 8, and Corel does the conversion. But, say I draw a circle in Corel and I get one continuous line, conversion to DXF yields about 500 something points all arranged in a circle. This makes it difficult to use certain machines like a waterJet or laser cutter because they want to cut every single point. Question: How can I use an existing drawing from Corel and convert it to DXF for use in QuickCAD and have my lines continuous? Is there something I need to do in AutoCAD to adjust or complete the lines after conversion, or is there a converter out there that will achieve my goal?
    Please use plain text.
    Distinguished Contributor
    Re: Converting from Corel CDR to DXF
    10-01-2007 03:05 PM in reply to: ASG - Robert
    corel draw 12 says its better for technical illustration
    pline edit..(PE) then, (J) join. that will make those continuous.
    search for 'corel and spline' in google...cnczone discusssion exists.
