• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    New Member
    Convert Drafix .cad file to Autocad 2010.. need help
    3898 Views, 5 Replies
    08-16-2009 12:48 PM
    I have some old .cad files I would like to re-use. They were last saved in 1997/1998 with .cad file extension. I think I was using Drafix but not sure. Can anyone convert for me? (File attached)
    Jack
    Please use plain text.
    New Member
    s0ckm0nkey
    Re: Convert Drafix .cad file to Autocad 2010.. need help
    01-19-2011 05:10 AM in reply to: jgutsch
    Hi don't have a solution to conversion yet, but can tell you that your file was created in Drafix:
    February 15, 1996
    Drafix Windows CAD
    IBM PC
    DOS 3.0
    MS 2.1
    1989 Foresight Resources Corp.
    Best of luck.
    Member
    johnsdtn40
    02-08-2011 12:27 PM in reply to: jgutsch
    I have an old copy of Drafix running I will try to download the file and convert it an Autocad file.  Where can I contact you off the borad?
    John Davis
    Member
    johnsdtn40
    02-08-2011 12:36 PM in reply to: johnsdtn40
    I was able to convert it to a .DWG and a DXF file  I hope it helps.
    John Davis
    New Member
    s0ckm0nkey
    02-08-2011 08:44 PM in reply to: jgutsch
    For information:
    I think that AutoSketch 10 has included the facility for opening old Drafix files. Once open you can save as AutoCAD .dwg.
    Glad you got it sorted.
    Active Member
    09-29-2011 01:57 PM in reply to: johnsdtn40
    Hello John,
    Was wondering if you could convert a few files for me.  I have run into these .cad files also and can't find anything to open them short of spending $150-200 and they just aren't worth that to do it.  If you could I would really appreciate it!
    Patrick
    P.S. I'll attach them later if are willing.
    Thanks again!
