• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    QuickCAD
    *DMH
    Adjusting screen line widths in V7
    12 Views, 1 Replies
    02-23-2000 08:27 PM
    I have QuickCad V7 (Millenium) and find the line widths appear really THICK
    on screen when set to anything above 2. Plot widths are fine but the drawing
    is difficult to work on when not zoomed in close. Is there a way to scale
    the screen widths like there is in Autocad 2000? It almost makes the program
    unusable.
    Thanks David H
    Please use plain text.
    *Rafuse, L.
    Re: Adjusting screen line widths in V7
    02-28-2000 05:05 AM in reply to: *DMH
    As far as I know, if you use the regular line thickness, you are stuck with a
    miserable looking on screen unless you are zoomed in.
    You may want to try using polylines and setting the poly line thickness not the
    regular line thickness. This looks much better.
    Len Rafuse
    Vision Engineering
    > unusable.
    > Thanks David H
