Quantity Takeoff (Read Only)
QTO fails to install even when i have autocad installed, gives error result 1819
1 REPLY 1
mugandaisaac
1276 Views, 1 Reply
hei, i have autocad installed, and i tried installing qto and it failed but true view installed successfully! gives error rollback directx result 1619
here is the log file:
2012/4/9:20:58:20 nOptimus NOPTIMUS-ISO === Setup started on NOPTIMUS-ISO by nOptimus ===
2012/4/9:20:58:20 nOptimus NOPTIMUS-ISO Launch
2012/4/9:20:59:51 nOptimus NOPTIMUS-ISO === Setup ended ===
2012/4/9:20:58:21 nOptimus NOPTIMUS-ISO === Setup started on NOPTIMUS-ISO by nOptimus ===
2012/4/9:20:58:21 nOptimus NOPTIMUS-ISO Launch
2012/4/9:20:59:53 nOptimus NOPTIMUS-ISO PageOpen LaunchDialog
2012/4/9:21:00:02 nOptimus NOPTIMUS-ISO PageOpen LicenseDialog
2012/4/9:21:00:15 nOptimus NOPTIMUS-ISO PageOpen LaunchDialog
2012/4/9:21:00:32 nOptimus NOPTIMUS-ISO PageOpen LicenseDialog
2012/4/9:21:01:17 nOptimus NOPTIMUS-ISO PageOpen ProductInfoDialog
2012/4/9:21:02:24 nOptimus NOPTIMUS-ISO PageOpen ProductSelectionDialog2
2012/4/9:21:02:55 nOptimus NOPTIMUS-ISO PageOpen FullProgressDialog
2012/4/9:21:02:56 nOptimus NOPTIMUS-ISO Installing DirectX® Runtime: C:\Autodesk\Autodesk_Quanitiy_Takeoff_2012_English_Win_32Bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/9:21:04:11 nOptimus NOPTIMUS-ISO Install DirectX® Runtime Succeeded
2012/4/9:21:04:11 nOptimus NOPTIMUS-ISO Installing Autodesk® DWG TrueView™ 2012: INSTALLDIR="C:\Program Files\Autodesk\DWG TrueView 2012\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Quanitiy_Takeoff_2012_English_Win_32Bit\" INSTALLDIR="C:\Program Files\Autodesk\DWG TrueView 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/9:21:06:36 nOptimus NOPTIMUS-ISO Install Autodesk® DWG TrueView™ 2012 Succeeded
2012/4/9:21:06:36 nOptimus NOPTIMUS-ISO Installing Microsoft Visual C++ 2010 Redistributable (x86): C:\Autodesk\Autodesk_Quanitiy_Takeoff_2012_English_Win_32Bit\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q
2012/4/9:21:06:41 nOptimus NOPTIMUS-ISO Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/4/9:21:06:41 nOptimus NOPTIMUS-ISO Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
1 REPLY 1
mugandaisaac
in reply to: mugandaisaac
oh, i fixed it. i just had to uninstall microsoft redistributable (x86) 2010. then i reinstalled qto using the main setup.exe file
