Quantity Takeoff
New Member
Message 1 of 2 (796 Views)
Autodesk QTO Horizontal& Vertical Scale
796 Views, 1 Replies
07-24-2012 08:32 AM
I have Autodesk QTO 2013, Im currently working on a project using PDF files :smileysad:. Poor contractors. My problem is that in the plan and profile sheets the scale is different for each axis. I would like to know if there is any suggestions for this issue. I need to get a little bit more accurate with the qty it seems that i am getting 8% or more at times without having the correct scale setup.
Member
Message 2 of 2 (745 Views)
Re: Autodesk QTO Horizontal& Vertical Scale
08-13-2012 08:56 AM in reply to: rmoomaw
Do you need to take off area measurements or linear?  Why the exaggerated scale - are you working with cross sections?
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
