Quantity Takeoff
New Member
athwal2k
Message 1 of 7 (1,703 Views)
Autodesk QTO 2013 Compatibility to Windows 8 Pro
1703 Views, 6 Replies
12-08-2012 10:10 PM
Recently i upgraded my pc from windows 7 to windows 8. After installing QTO 2013, when i tried to open an existing file made in QTO 2013 previously, it was not opening showing the message "this file is made in a newer version of QTO than installed version on this pc. so it can't be opened." Any solution. Experts plz.
New Member
athwal2k
Message 2 of 7 (1,678 Views)
Any solution plz.
12-12-2012 10:18 PM in reply to: athwal2k
Any solution plz.
New Member
sjw32
Message 3 of 7 (1,598 Views)
Re: Autodesk QTO 2013 Compatibility to Windows 8 Pro
12-29-2012 08:19 PM in reply to: athwal2k
Has anyone offered solution to your problem? I have the same issue. Thanks.
New Member
ggirgin
Message 4 of 7 (1,492 Views)
01-23-2013 06:46 AM in reply to: athwal2k
Click right mouse button on Autodesk QTO icon and go to "check solution compatibilty" use" I ran this program on Win 7 correctly."
Icon should be on your desktop not on the ribbon!
 Take care!!!!
New Member
simon.green
Message 5 of 7 (1,350 Views)
02-22-2013 09:50 AM in reply to: athwal2k
Thanks. the solution worked.
New Member
m.anas
Message 6 of 7 (274 Views)
04-20-2014 03:00 PM in reply to: simon.green
When I open QTO in windos 8.1 give me this message" Cannot ope project. the project file you selected is from a version of the producr that newer than the version you have installed " any solution ?!
New Member
ggirgin
Message 7 of 7 (270 Views)
04-20-2014 09:28 PM in reply to: m.anas
There may be two reasons. First, did you apply hotfix for QTO 2013 ? Please, be sure you made it. If you don't, you may always lose your data. Then, try to open your file in compatibility mode. And save this choice in Win 7.
G.Girgin
Civ.Eng. (M.Eng)
You are not logged in.
Ask the Community
