Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Python
Valued Contributor
spark
map scripts to input device?
90 Views, 3 Replies
08-31-2010 05:43 PM
If I plug in a joystick is it possible to map scripts to various buttons and whatnot on the joystick?
Please use plain text.
Active Member
Trizoy
Re: map scripts to input device?
09-01-2010 04:53 PM in reply to: spark
It sure is :smileyhappy:
1)First, drop a 'Script' device into the scene.
2)Next, create a relation constraint, and add the script device as the receiver.
3)Now you'll want to add the script you've made to your scene.
4)At this point, you'll see the script appear as an item within the 'script device'; you'll be able to connect things to it as you would any kBox.
5)Finally, drop your joystick device into the relation constraint, and connect your script with the desired button on the joystick.
Note: Keep in mind that the script event will trigger when a boolean value of 1 is reached from the joystick (how most joysticks indicate a button press).
Valued Contributor
spark
03-21-2012 03:18 PM in reply to: spark
As a follow-up to this, I'd like to map camera controls to a joystick, but I'm at a complete loss as to where to start.
If I drag a created Camera into the Relations or Expression constraint pane, I only get the camera's TRS.
For example, if I plugged in an XBox controller in and hit the "A" button, I'd like for that to toggle the "Lock Interest Navigation" checkbox.
If I move the right stick left or right I want to rotate around the interest point, etc.
As it is, the only values I can seemingly constrain are the camera's TRS?
Put simply, I want CTRL-SHIFT-LMB to get mapped to the right analog stick of the 360 controller.
Is that even possible?
omnized
03-21-2012 03:31 PM in reply to: spark
This might be what you want, or at least set on you on the right path to getting there :smileywink:
http://gware.blogspot.com/2010/03/fps-camera-in-motion-builder-using.html
