I have a scene with a skinned mesh. No actor, no animation data on the mesh.
I want to load a custom data file and have the character move about.
The format is similar to BVH - one part to describe the hierarchy, one part of data.
What's the most efficient way? I imagine I may end up having to use the SDK for speed's sake, but I wanted to give python a shot, first.
Assume that the data from the file is loaded in memory and is accessed in a sensible way, e.g.
Data.LeftArm.RotateX = lcl RotateX value at frame 0
Data.LeftArm.RotateY = lcl RotateX value at frame 1
Data.RightAnkle.Translate = lcl Translate value at frame 0
So I'm thinking I'd have to loop thru each frame, then for each bone, find its Translate/Rotate/Scale's AnimationNode's XYZ AnimationNode's FCurve, do a KeyAdd and set the value from Data.LeftArm.RotateX?
Sounds rather easy, but a bit cumbersome and slow. I guess I can't set the FCurve to some array of data?
