I'm stuck and confused. What can cause MoBu to enter a state where it returns different python objects for the same object in Mobu. EG:
import pyfbsdk pyfbsdk.FBApplication().FileNew() def run_test(): my_cube = pyfbsdk.FBModelCube('my_cube') comp_list = pyfbsdk.FBComponentList() pyfbsdk.FBFindObjectsByName( my_cube.Name, comp_list, False, True ) my_cube_found_by_name = comp_list[0] print 'my_cube.FullName = \t\t\t', my_cube.FullName print 'my_cube object = \t\t\t', my_cube print 'my_cube_found_by_name.FullName = \t', my_cube_found_by_name.FullName print 'my_cube_found_by_name object = \t', my_cube_found_by_name print 'my_cube == my_cube_found_by_name : {0}'.format( my_cube == my_cube_found_by_name ) return my_cube, my_cube_found_by_name run_test()
on a fresh session of MotionBuilder returns:
>>> my_cube.FullName = Model::my_cube
>>> my_cube object = <pyfbsdk.FBModelCube object at 0x000000003B996638>
>>> my_cube_found_by_name.FullName = Model::my_cube
>>> my_cube_found_by_name object = <pyfbsdk.FBModelCube object at 0x000000003B996638>
>>> my_cube == my_cube_found_by_name : True
However, after a while of running other scripts, I get this:
>>> my_cube object = <pyfbsdk.FBModelCube object at 0x000000003B919A98>
>>> my_cube_found_by_name object = <pyfbsdk.FBModelCube object at 0x000000003B9252E8>
>>> my_cube == my_cube_found_by_name : False
Anyone have explanatin, ideas, or suggetions?
Autodesk was kind enough to look into this with me. After some back and forth, we narrowed it down to a callback that I had active. Specifically, there is an issue with storing the node, found via event.ChildComponent, into a variable(global, namespaced, or otherwise). Storing the name of the node is fine, just not the python object. This workaround is enough for my needs, but as I understand it the issue is being reported as a bug.
Here is some sample code that reproduces the problem...
import pyfbsdk ##pyfbsdk.FBApplication().FileNew() sys = pyfbsdk.FBSystem() scn = sys.Scene new_nodes = {} def run_test(): my_cube = pyfbsdk.FBModelCube('my_cube') comp_list = pyfbsdk.FBComponentList() pyfbsdk.FBFindObjectsByName( my_cube.Name, comp_list, False, True ) my_cube_found_by_name = comp_list[0] print 'my_cube.FullName = \t\t\t', my_cube.FullName print 'my_cube object = \t\t\t', my_cube print 'my_cube_found_by_name.FullName = \t', my_cube_found_by_name.FullName print 'my_cube_found_by_name object = \t', my_cube_found_by_name print 'my_cube == my_cube_found_by_name : {0}\n'.format( my_cube == my_cube_found_by_name ) return my_cube, my_cube_found_by_name def my_callback( control, event ): if event.Type == pyfbsdk.FBSceneChangeType.kFBSceneChangeAttach: node = event.ChildComponent node_cgn = node.ClassGroupName if node_cgn == 'Model': if not node_cgn in new_nodes: new_nodes[ node_cgn ] = { node.__hash__(): node } else: new_nodes[ node_cgn ][ node.__hash__() ] = node c1, c2 = run_test() scn.OnChange.Add( my_callback ) c3, c4 = run_test() scn.OnChange.Remove( my_callback ) c5, c6 = run_test()
...which results in:
my_cube.FullName = Model::my_cube 22
my_cube object = <pyfbsdk.FBModelCube object at 0x000000003CDD33B8>
my_cube_found_by_name.FullName = Model::my_cube 22
my_cube_found_by_name object = <pyfbsdk.FBModelCube object at 0x000000003CDD33B8>
my_cube.FullName = Model::my_cube 23
my_cube object = <pyfbsdk.FBModelCube object at 0x000000003CDD3408>
my_cube_found_by_name.FullName = Model::my_cube 23
my_cube_found_by_name object = <pyfbsdk.FBModelCube object at 0x000000003C9507B8>
my_cube.FullName = Model::my_cube 24
my_cube object = <pyfbsdk.FBModelCube object at 0x000000003CDD3318>
my_cube_found_by_name.FullName = Model::my_cube 24
my_cube_found_by_name object = <pyfbsdk.FBModelCube object at 0x000000003CDD3318>
huh, that's nasty thingy You found!
a side note on references and events -
I suggest that You were rather careful when working with these event handlers. Especially problematic may be certain handlers that may remain active when MoBu is being shut down, no matter how hard I tried to catch shutdown and remove handlers, use try/except clauses etc, the handler still may crash MB... so it shuts down and in some final stage crashes 🙂 Simply, don't be surprised that certain code may behave unusually in event handler function.
references - I had some weird situations when I got references to a Fcurve, then I realized that after I changed the layer or what was it - can't remember exactly, the reference got lost (unbound object). Hours of headbanging until I nailed that down finally.
Hopefully, searching the object by name might always return proper reference, even though it is slow, of course.
Stepan
