MotionBuilder Forum
Welcome to Autodesk’s MotionBuilder Forums. Share your knowledge, ask questions, and explore popular MotionBuilder topics.
Script equivalent of "Plot All (all Properties)"?
7 REPLIES 7
Message 1 of 8
ZoltanE
1366 Views, 7 Replies
What is the script equivalent of the "Plot All (all Properties)"
menu item?
I checked out quite a few scripts but I only saw examples for
plotting on characters by calling the PlotAnimation() function.
I could iterate through all animated objects and plot each one
but I reckon a more direct solution would be faster.
7 REPLIES 7
Message 2 of 8
sismikkk
in reply to: ZoltanE
Up ! 6 years later...
Message 3 of 8
evan.cox
in reply to: sismikkk
Populate your list of selected objects...
objs = # your list here
pyfbsdk.FBSystem().CurrentTake.PlotTakeOnObjects( pyfbsdk.FBTime(0,0,0,0), objs )
Message 4 of 8
sismikkk
in reply to: evan.cox
It tells me
AttributeError: 'FBTake' object has no attribute 'PlotTakeOnObjects'
I had the same issue when trying to use "PlotAllTakesOnProperties". Only method i could use was "PlotAllTakesOnSelectedProperties".
But then i couldn't manage to get all properties selected with this code :
gplot = FBPlotOptions ()
gplot.PlotPeriod = FBTime(0,0,0,1)
modelList = FBModelList ()
FBGetSelectedModels (modelList, None, True)
for model in modelList:
    propList = model.PropertyList
    for prop in propList:
        prop.Selected = True
        prop.SetFocus(True)
FBSystem().CurrentTake.PlotAllTakesOnSelectedProperties(gplot.PlotPeriod)
Neither
or
prop.SetFocus(True)
worked =/
Message 5 of 8
sismikkk
Ok so my previous code didn't return me any model cause no model were selected, so i replaced it with
for model in FBSystem().Scene.RootModel.Children:
Now i get all the models i'm interested in but still none of prop.Selected = True or prop.SetFocus(True) works.
Message 6 of 8
sismikkk
And i just found out that i can't use PlotAllTakesOnProperties because this function is not present in motionbuilder 2013 (that i'm using) and i was reading the 2014 motionbuilder documentation =(
Message 7 of 8
bujinkan02
I've tried this code and it seems to work fine (Mobu 2013 SP2). You don't need to set the focus on the property you want to plot, the selected attribute is enough, SetFocus just highlight the property in the property editor GUI.
from pyfbsdk import *
Cheers
Message 8 of 8
sismikkk
in reply to: bujinkan02
Thank you ! I used another way but your code works too !
