Area :: Header
Join us at EUE2014, June 5-6, Utrecht-NL
Register Now
Discussion Groups
Python
Member
DavidJamesBailey
Connecting and setting values on Macros in relation constraint
49 Views, 5 Replies
12-02-2010 04:02 AM
Hi there,
I am having trouble making connections and setting values on Macro boxes within a relation constraint with python. When trying to create a connection there is no error but nothing happens, and when trying to write data to an input it will error:
AttributeError: 'NoneType' object has no attribute 'WriteData'
I have tried changing the 'Input' and 'Output' names but cannot find a way to make it work. Any ideas?
Please use plain text.
Valued Contributor
rig_vader
Re: Connecting and setting values on Macros in relation constraint
12-07-2010 04:16 AM in reply to: DavidJamesBailey
Are you using FBConnect() to make the connections?
Member
DavidJamesBailey
12-07-2010 07:31 AM in reply to: rig_vader
Yes I use FBConnect() to try and make the connections between the Macro boxes, it doesn't work, but it works fine between any other type of Box!
Valued Contributor
rig_vader
12-07-2010 08:58 AM in reply to: DavidJamesBailey
I'm sure I have some code connecting macros somewhere.. I'll try to find it and post
Valued Contributor
rig_vader
12-08-2010 12:45 AM in reply to: rig_vader
I think I might have hooked up macros from python at some point.. but unfortunately I'm hazy on the when and how. I could not find anything in my code base, but I remember having the same issue - I think I must have choosen a workflow that did not require me to hook up macros from Python. Sorry
middlek
12-11-2010 10:44 AM in reply to: DavidJamesBailey
The main issue with not being able to connect to Macro box within a relation constraint is the name you are passing here, is not finding the name:
ConnectBox(inputOutput, 'Output', inputOutput1, 'Input')
You either need to use the function:
FBAnimationNode FindByLabel
str
pNodeLabel
Returns the animation node from its label.
Parameters:
pNodeLabel
Label of the searched animation node.
Returns:
AnimationNode found.
Or you need to look to see what the auto generated names are by MotionBuilder, like this:
lMacro = lRelation.CreateFunctionBox('My Macros', 'HelperBoneControl')
lRelation.SetBoxPosition(lMacro,300,200)
#Testing what the real Animation Node names are, they don't reflect what is in the UI for Macros
lMacroIN = lMacro.AnimationNodeInGet().Nodes
for lAnimationNode in lMacroIN:
print "IN: (%s) " % (lAnimationNode.UserName)
lMacroOUT = lMacro.AnimationNodeOutGet().Nodes
for lAnimationNode in lMacroOUT:
print "OUT: (%s) " % (lAnimationNode.UserName)
lMacroIn = FindAnimationNode( lMacro.AnimationNodeInGet(), 'MacroInput0' )
lMacroOut = FindAnimationNode( lMacro.AnimationNodeOutGet(), 'MacroOutput1' )
~Kristine
KRISTINE MIDDLEMISS | ANIMATION TECHNICAL ARTIST
