Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Python
Valued Contributor
Avalon_1
BUG? MB2010 Shaders
7 Views, 2 Replies
01-15-2010 02:54 AM
Has anyone else experienced this?
I get the same thing in both OR and from within the python editor... or did I miss something?
I've tried it on two different machines and get the same result.
A simple test code:
from pyfbsdk import *
lShaderManager = FBShaderManager()
lBox = FBModelCube("Test")
lBox.Show = True
lShader = lShaderManager.CreateShader("WireShader")
if(lShader):
#All do the same thing...none works
lBox.Shaders.append(lShader)
lShader.ReplaceAll(lBox)
#FBConnect(lShader,lBox)
It actully applies the shader to the model but it doesnt seems to connect it. If I drag and drop it, it works...
Cheers,
AV
Choose a job you love, and you will never have to work a day in your life.
Please use plain text.
Valued Contributor
Jacques.LIAO
Re: BUG? MB2010 Shaders
01-21-2010 06:19 AM in reply to: Avalon_1
Turn on the propriate shading mode, with D&D the application will automatically adjust the shading mode, but with Python Script, you need to do it by yourself.
lBox.ShadingMode = FBModelShadingMode.kFBModelShadingAll
Jacques LIAO
Freelancer / Consultant programmer for MotionBuilder and Virtual production
Valued Contributor
Avalon_1
01-21-2010 06:44 AM in reply to: Jacques.LIAO
Excellent!
Thank you for that info!
Cheers,
Av
