Area :: Header
Meet the Experts Webinar
Learn how Black Forest Games rebooted the classic C64 platform game “Giana Sisters” from 1987 using Autodesk 3ds Max®.
Discussion Groups
Python
Member
Anyone successful in using python in MoBu 2011?
37 Views, 6 Replies
04-20-2010 05:59 AM
I installed MoBu 2011 Tryout but I'm unable to get Python working! At openening the script editor window, I get error messages: ...ImportError: No module named pyfbsdk... and ...ImportError: No module named pyfbsdk_additions...
I tried it on two computers: Win7 64 and Win7 32
Anyone was able to use Python in MoBu 2011?
Thanks in advance
Please use plain text.
Valued Contributor
Re: Anyone successful in using python in MoBu 2011?
04-22-2010 03:02 AM in reply to: Takichi
Of course. Works as intended.
You must have some Installation or OS Problems here...
Member
04-29-2010 04:51 AM in reply to: Takichi
It seems it had a conflict with the Python and PyQt installed on my computers, removed both and replaced with Python 2.6.4 and PyQt 4.5.2 and everything is working.
Active Contributor
11-09-2010 05:34 AM in reply to: Takichi
I have the same problem:
Traceback (most recent call last):
File "<MotionBuilder>", line 1, in <module>
File "C:/Users/XXXXX/AppData/Local/Autodesk/MB2011x64/config/Python/pythonidelib.py", line 1, in <module>
import pyfbsdk
Opening Python Editor and doing import pyfbsdk also gives no module named. This is on a few weeks old install of Win7 64bits. Just tried installing Python 2.6.4 but it didn't chang anything. I will try to install PyQt, but I doubt it might make a difference.
I can't find anything on the net related to this error. Any ideas? It's kinda urgent.
Edit: reinstalling MoBu2011 did the trick. Don't know if having Python and PyQt already installed made any difference though...
Active Member
tallystick
11-27-2010 05:39 PM in reply to: Takichi
That's a problem with your python path. Search for how to add those files/directories to your python path and you should be able to solve it that way rather than resorting to a reinstall.
Valued Contributor
spark
12-07-2010 01:55 PM in reply to: Takichi
I don't think so.
I applied the hotfix for the 64-bit version of MB 2011 and I am experiencing the same issue with being unable to run scripts (from pyfbsdk import * doesn't work).
I set the PYTHON_PATH environment variable to point to the directory containing pyfbsdk and I still get the same error.
I've contacted Autodesk support but still no word.
Anyone else?
Active Member
tallystick
12-10-2010 02:17 PM in reply to: Takichi
Did you add it to your .pth or from the python shell? Adding it from the python shell only works for that session.
http://greeennotebook.com/2010/06/how-to-change-pythonpath-in-windows-and-ubuntu/
