• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Public Works
    New Member
    dxf
    686 Views, 2 Replies
    03-06-2009 11:08 PM
    Hello everybody
    I am trying to convert ORCAD file to ACAD file
    -I make electrical drawing by ORCAD (with extention *.DSN)
    -From ORCAD expert file to *.DXF -> OK
    -ACAD2007 open file (from ORCAD) with file of type DXF but can not with message :invalid or incomplate DXF input -drawing discarded .
    Could you help me to solve it ?
    I will appreciate your quick responses
    Thanks in advance
    Best Regards
    tvlap
    Please use plain text.
    New Member
    Re: dxf
    05-31-2009 08:18 PM in reply to: tvlap
    You can try overcad dwg dxf converter, it can convert DWG and DXF files back and forth between R14, 2002, 2004 and 2007 versions.
    Edited by: autochrysler on Jun 1, 2009 3:18 AM Edited by: autochrysler on Jun 1, 2009 3:20 AM
    Active Member
    Re: dxf
    06-29-2009 10:59 PM in reply to: tvlap
    You can try to recover the DXF in AutoCAD first, enter "recover" in command line and choose your draiwng to recover in AutoCAD. If this still not helps, you can try AutoDWG DWG DXF converter at http://www.autodwg.com/DWG_DXF_Converter/ and try to version conversion to see if the drawing can be recovered.
