• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Public Works
    .dgn files to acad .dwg
    10989 Views, 11 Replies
    12-17-2004 06:50 AM
    how to change .dgn files into
    acad .dwg files
    Please use plain text.
    *Kelly Boyd
    Re: .dgn files to acad .dwg
    12-17-2004 08:34 AM in reply to: sbsmith
    Do you currently have a copy of AutoCAD Map or AutoCAD LDT? If so, there's an option for importing several different formats including MicroStation DGN's. All you have to do is select "Import" from the "Tools" section of the Map pulldown menu (i.e. Map > Tools > Import). Then select MicroStation Design (*.dgn) from the "Files of type:" field and select the file you wish to import. If you don't have Map or LDT, then you'll need to have someone who has access to one of these translate the file for you. Or you can ask the person and/or organization who owns the DGN file to save it as a DWG file (MicroStation has the ability to do this.) Kelly W. Boyd CAD/CAE Support Engineer Pierce County Public Works (remove ns from e-mail address to reply) >>> sbsmith 12/17/04 06:50AM >>> how to change .dgn files into acad .dwg files
    12-17-2004 11:41 AM in reply to: sbsmith
    thank you for your reply, Kelly
    I'm with a Munipality Engineering Dept. and am trying to
    convert from Eaglepoint Software. It's like a different
    language almost.
    New Member
    01-07-2005 12:30 PM in reply to: sbsmith
    Use Autodesk Map.
    MAP/IMPORT pulldown.
    New Member
    10-25-2005 10:47 PM in reply to: sbsmith
    To change the dgn file to dwg (drawing file)
    New Member
    05-02-2006 01:41 PM in reply to: sbsmith
    Kelly,
    I do not have the import option under tools menu. I save the microstation drawing as a ".dwg" file when I try to open the file using Autocad and get an error message "file not valid".
    Can you help me with this?
    *melanie stone
    05-15-2006 05:46 AM in reply to: sbsmith
    how do you save the ms drawing as dwg? from within microstation? or with
    autodesk MAP?
    wrote in message news:5161504@discussion.autodesk.com...
    Kelly,
    Member
    05-12-2008 08:57 AM in reply to: sbsmith
    Kelly,
    I tried using my map option to convert dgn to dwg. It worked, but it seems the .cel that are associated with the drawings did not convert. Is there another way to get the dgn file with the .cel files to all convert in one move?
    07-19-2008 03:42 PM in reply to: sbsmith
    Hi! Kelly
    Im new to CAD what is a DWG File, DGN File and the meaning of Map or LDT..
    Are you trying to say that Auto Cad can open any other drawing from different softwares ex: Microstation, 3d Max, CAD Eagle...
    New Member
    REG: DGN File
    02-27-2009 09:26 PM in reply to: sbsmith
    I am working with GPS Map. I want to embed the GPS MAP in to JAVA or .NET application. I want to know the possibilities to develop the DGN File Viewer and API.
