• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Project Spark
    Active Member
    problems installing
    68 Views, 3 Replies
    09-30-2011 03:57 AM
    why can't i install the thing?
    2011/9/30:11:36:17 russ PC10107 === Setup started on PC10107 by russ ===
    2011/9/30:11:36:17 russ PC10107 Launch
    2011/9/30:11:36:32 russ PC10107 === Setup ended ===
    2011/9/30:11:36:31 russ PC10107 PageOpen LaunchDialog
    2011/9/30:11:36:36 russ PC10107 PageOpen LicenseDialog
    2011/9/30:11:36:38 russ PC10107 PageOpen ProductInfoDialog
    2011/9/30:11:36:49 russ PC10107 PageOpen ProductSelectionDialog2
    2011/9/30:11:37:08 russ PC10107 PageOpen FullProgressDialog
    2011/9/30:11:37:08 russ PC10107 Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\AutodeskProjectSpark\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\russ\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2011/9/30:11:37:15 russ PC10107 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
    2011/9/30:11:37:15 russ PC10107 Installing DirectX® Runtime: C:\Autodesk\AutodeskProjectSpark\3rdParty\DirectX\DXSETUP.exe /silent
    2011/9/30:11:37:49 russ PC10107 Install DirectX® Runtime Succeeded
    2011/9/30:11:37:49 russ PC10107 Installing VSTA aide:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutodeskProjectSpark\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    Russ Green
    http://www.archisoft.co.uk/blog
    Active Member
    Re: problems installing
    09-30-2011 09:07 AM in reply to: russ.green
    OK....got it installed but no UK content??
    Russ Green
    Employee
    loboarch
    10-11-2011 05:52 AM in reply to: russ.green
    I am glad you were able to get Spark to install correctly.  Spark is a technology preview and localized content was not provided.  It is still good feedback for our team to know this content is important to you as a user.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Active Member
    10-11-2011 06:23 AM in reply to: russ.green
    not sure how much of a preview it is as its a bit unclear why its different from revit with the concept modelling and rendering removed....if the non-compatibility with revit on the files is to be permanent then its useless technology.
    Russ Green
