Project Spark
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Where are the templates for Spark?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK could be just my install but on opening the package I get error messages:-
The default template file you have specified does not exist..... then
The path you have specified for the default family template is invalid
Under Options the Default template file path is blank and the Defail path for the family templates files is \templates
Under C:\ProgramData\Autodesk I have the RST 2012 but now also have RLT with nothing below but no Spark (Ummm which is kind of Revit LT)
Is this a UK or World install **** up on Autodesks part or just my install?
Re: Where are the templates for Spark?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
From your description it sounds like the install did not complete all the way or had some kind of error. You should be seeing a number of folders at that location including the template files. You may want to try the installation again just in case there was some kind of trouble with your during your install.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Jeff
There was no error report when I installed it at Home last night, I have installed it at work today and it has completed the install of the families under RLT as I expected, I will un-install and re-install at home again tonight and see how it goes.
It's really silly that it's the same file extension but not the same file format as Full Revit, what's the reason for this?
Regards
Alan
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The FAQ on the Spark page at labs was updated to make this a bit more clear. Project Spark uses a newer Revit file format, it is not currently possible to open files created in Project Spark with Revit 2012.
Jeff Hanson
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If you're experiencing this problem, could you please post:
* What operating system you're using and whether it's 32 or 64 bit
* Whether you changed the settings at install time at all (e.g. did you select only metric content or only imperial)
This will help us track the problem down.
I tried to attach the template here, but unfortunately this forum is very limited in the file sizes it will accept. I will see what I can do to get it posted somewhere else accessible. Sorry for the inconvenience!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
We still don't know why the content doesn't install for some people. However, for those who are experiencing this problem, the content is now available as a separate download here:
http://labs.autodesk.com/utilities/spark/content/
Sorry for the inconvenience,
Emily
