• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Project Spark
    Active Contributor
    Accepted Solution
    Project Spark - Simplified families and Export
    102 Views, 4 Replies
    02-07-2012 08:51 AM
    I have not downloaded this product but have some questions.
    From this link below:
    http://www.mcquay.com/eprise/main/McQuay/BIM/images/Converting_a_Revit_Family_to_AutoCAD_-_using_Rev...
    From within Revit LT can:
    1. A family be loaded by selecting from the catalog?
    2. A MEP Revit Family be opened and modified by it's type parameters?
    3. Can the connections be removed?
    4. Can the family saved and loaded into a project?
    5. Can the family in a project be exported to DWG?
    Thanks very much,
    David
    Employee
    loboarch
    Re: Project Spark - Simplified families and Export
    02-10-2012 11:08 AM in reply to: David_Metcalf
    Project Spark can use/edit family files from Revit.  There is a limitation however in that any familes created/modified in Project Spark can not be used by Revit.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Employee
    loboarch
    02-10-2012 12:17 PM in reply to: David_Metcalf
    Thanks very much,
    David
    I realized I did not answer all of your questions directly.  For clarification:
    Yes families from Revit can be opened and a type catalog can be used.
    Yes you can open an MEP family and modify type parameters.
    Yes
    Yes it can be loaded into a Project Spark project.  It will not be able to be loaded into a Revit project.  If it is an MEP family however it may not matter if it is loaded into the project or not.  Since Project Spark does not have MEP tools some families may not be able to be placed even if they are loaded into the project.
    You can export familes and projects from Project Spark to DWG files.
    Jeff Hanson
    New Member
    dpower
    02-21-2012 06:10 AM in reply to: David_Metcalf
    Is it possible to retain information on materials when exporting a family into dwg format?
    Employee
    loboarch
    02-21-2012 06:15 AM in reply to: David_Metcalf
    A DWG export from Project Spark will not contain material information.  The FBX export will export a family with material information intact.
    Jeff Hanson
