Project Spark
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Project Spark - Simplified families and Export
- Highlight
- Email to a Friend
I have not downloaded this product but have some questions.
From this link below:
From within Revit LT can:
1. A family be loaded by selecting from the catalog?
2. A MEP Revit Family be opened and modified by it's type parameters?
3. Can the connections be removed?
4. Can the family saved and loaded into a project?
5. Can the family in a project be exported to DWG?
Thanks very much,
David
Re: Project Spark - Simplified families and Export
- Highlight
- Email to a Friend
Project Spark can use/edit family files from Revit. There is a limitation however in that any familes created/modified in Project Spark can not be used by Revit.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
- Highlight
- Email to a Friend
Thanks very much,
David
I realized I did not answer all of your questions directly. For clarification:
Yes families from Revit can be opened and a type catalog can be used.
Yes you can open an MEP family and modify type parameters.
Yes
Yes it can be loaded into a Project Spark project. It will not be able to be loaded into a Revit project. If it is an MEP family however it may not matter if it is loaded into the project or not. Since Project Spark does not have MEP tools some families may not be able to be placed even if they are loaded into the project.
You can export familes and projects from Project Spark to DWG files.
Jeff Hanson
- Highlight
- Email to a Friend
Is it possible to retain information on materials when exporting a family into dwg format?
- Highlight
- Email to a Friend
A DWG export from Project Spark will not contain material information. The FBX export will export a family with material information intact.
Jeff Hanson
