• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Project Spark
    Member
    Malcolangelo
    Accepted Solution
    Joining walls to roof
    181 Views, 4 Replies
    09-19-2011 05:00 AM
    I have been unable to attach (extend) walls to an extruded roof, If walls are selected for the rook outline an option prompt appears to ask if you would like to join the selected walls to the roof yes no , but are cant seem to find a way to join an extruded rook to those same walls. Help please.
    Employee
    loboarch
    Re: Joining walls to roof
    09-19-2011 05:12 AM in reply to: Malcolangelo
    The extruded roof behaves slightly different than a roof by footprint when walls need to be attached.  The roof made with the foot print option will offer to attach the walls to the roof.  This is not the case when a roof by extrusion is created over walls.
    In order to attach walls to an extruded roof, after the roof is created, select all of the walls you would like to attach to the extruded roof.  Then on the context tab of the ribbon click the "attach top/base" button.  Now select the extruded roof.
    Hope this helps solve you problem.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    Member
    Malcolangelo
    Re: Joining walls to roof, Floor plans not showing in project browser.
    09-20-2011 05:21 AM in reply to: loboarch
    Thanks Jeff,
    That worked fine.
    I have another issue as well, I have 5 levels in my project the 5th being  roof level so 4  floor plans, only level 1 & 2 are showing in the browser I have walls on all 4 floor levels how do I get to show level 3 & 4 floor plans in the browser, I am having no problems drawing on each level.
    Employee
    loboarch
    09-20-2011 05:38 AM in reply to: Malcolangelo
    Malcolangelo wrote:
    Thanks Jeff,
    That worked fine.
    Without seeing the project file I can't be sure, but I am going to guess the additional levels (levels 3-5) were added by making a copy of an existing level.  when this is done a new level datum is created but an associated floor plan is not.  You can tell the difference by the color of the level head in a section or elevation view.  If the level head is blue then there should be an associated plan in the project browser.  If the level head is black then it is just a datum line and no floor plan view has been created.
    To create a plan view for a level that does not have one you can go to the View tab of the ribbon and select the Floor Plan tool.  This will display a dialog with all of the datums in your project that currently do not have a plan view associated.  In this dialog you can select which datums you would like to create a plan view for and click "Ok".  Now the project browser will have the plan views for the other levels.
    Jeff Hanson
    Member
    Malcolangelo
    09-22-2011 05:23 AM in reply to: loboarch
