• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Project Galileo
    Active Contributor
    File Geodatabase access
    346 Views, 1 Replies
    12-21-2010 01:00 PM
    File geodatabase access please, with the current release of Esris Arc gis 10 much more data is being developed in file geodatabases instead of shp files, if you can add in the ability to connect to a file geodatabse that would make me and my gis staff happy. And it would help to keep my model current, by accessing the current data instead of the most recent export of the data.
    I know that the FDO recently came out for map 3d and that has helped a lot.
    Please use plain text.
    Employee
    Re: File Geodatabase access
    12-21-2010 03:44 PM in reply to: david.lawrence
    Yep, we've already run into this issue.  There may be an update to FDO that includes a file-based geodatabase provider.  If that was released, then it would be a simple manner of adding in the provider. I'll check up on this and see if any announcements are imminent.
    Thanks!
    Senior Product Manager, Life Sciences
    Media and Entertainment
