Project Falcon
New Member
craig.gaudet
Message 1 of 7 (420 Views)
Falcon for Inventor 2012 Crashes on Simulation Changes
420 Views, 6 Replies
01-07-2013 10:58 AM
I am having stability issues with Falcon running as an Add-In for Inventor 2012.  Whenever I try to change any of the simulation settings:
3D:
   Flow Direction
   Domain Size
   Flow Speed
   Resolution
2D:
   Move cross section plane
...Inventor crashes.  I can start the simulation, change the visualization style, and that's about it.  Also, when I try to look at the Drag graph, a grey box pops up on my screen, but no data is plotted.  On install, I followed these instructions:
http://labs.blogs.com/its_alive_in_the_lab/2011/10/unblock-technology-previews-before-installing-for...
to unblock technology previews.  Also, for some reason, I had to specify that my install directory is:
C:\ProgramData\Autodesk\Inventor 2012\Addins
The default was trying to install in a non-existing AutoCAD 2013 directory (even though I have 2012).
This does significantly limit the usabilty of the program for me - are there any suggestions for how I can resolve this?
Board Manager
scott.sheppard
Message 2 of 7 (403 Views)
Re: Falcon for Inventor 2012 Crashes on Simulation Changes
01-15-2013 09:03 AM in reply to: craig.gaudet
I only have Inventor 2013 listed on the supported applications page.
http://labs.autodesk.com/utilities/falcon/supported_apps
Scott Sheppard
Program Manager
Autodesk Labs
Autodesk, Inc.
New Member
craig.gaudet
Message 3 of 7 (401 Views)
01-15-2013 09:40 AM in reply to: craig.gaudet
That would do it.  Thanks for the reply.
Distinguished Contributor
miechh
Message 4 of 7 (375 Views)
01-30-2013 11:10 PM in reply to: craig.gaudet
I also installed Falcon, but I'm using it stand-alone. I too have stability problems with Falcon. Every time I want to change appearance settings (flow lines instead of cloud) or drag the view planes or whatever change, Falcon crashes. I can't reproduce the steps needed to say which one causes the crash, because Falcon crashes on different occasions/changes. Pretty annoying when you realise that the same problems still occurs although I upgraded from an Windows XP 32-bit machine to a Windows 7 Pro 64bit Xeon machine.
Product Design Suite 2014
Inventor 2014, Vault 2014
HP Workstation Z220
Intel Xeon 3.4GHz
16GB RAM
Nvidia Quadro 4000
Windows 7 Professional (64bit)
Employee
hartogj
Message 5 of 7 (352 Views)
02-21-2013 07:16 PM in reply to: miechh
Sorry to hear about the trouble. Stability seems to be good on many machines but there are some where issues have come up. Our team is looking at some improvements to the platform that will hopefully help.
In the meantime, some of those that have had trouble found the change below helpful. No guarantees but may be worth a try.
1) Change the Shader option to "0" in the "settings.ini" file in your Falcon installation folder:
[Settings]
Reset=0
Shader=0
UI=0
Velocity-X=10.000000
Velocity-Y=-0.000100
2) Start Falcon and see if that resolves the problem
miechh
Message 6 of 7 (340 Views)
02-24-2013 11:01 PM in reply to: hartogj
Thanks for your reply, hartogj. I'd like to try the changes to be made in the settings.ini, but I can't find this .ini file in the installation folder of Falcon. Not in the Program Files, nor in the Program Files X86 folder. The visibility of system-files/folders is enabled in Windows, so I should see all hidden files/folders. Is it possible that the settings.ini file is in another location, like in the users-folder or the documents and settings folder? A search-command in these folders gives no result.
HP Workstation Z220
Intel Xeon 3.4GHz
16GB RAM
Nvidia Quadro 4000
Employee
hartogj
Message 7 of 7 (333 Views)
02-25-2013 12:04 PM in reply to: miechh
If the settings.ini file is not there it is an indication we haven't had any successful sessions yet on that system.
I spoke with another person 2 weeks ago who was having similar issues until he re-downloaded the installer using a different browser. Can you try re-downloading from the main project page? I will temporarily post an alternate build here in case you want to test downloading from a different source.
You are not logged in.
Announcements
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Need installation help?
Ask the Community
