• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Project Falcon
    New Member
    Falcon - Minimum distance between two objects
    77 Views, 1 Replies
    02-06-2013 05:18 AM
    What is the minimum distance between two objects until Falcon determines the gap is a solid object? I saw the example videos that showed models as large as a building and as small as a car. If the scale does not matter, if I put two rectangular towers next to each other how close can I put them until the air flow stops flowing between them?
    Please use plain text.
    Employee
    hartogj
    Re: Falcon - Minimum distance between two objects
    02-21-2013 07:01 PM in reply to: calmojuela
    This depends more on the resolution than the absolute dimensions of the geometry.
    With lower resolution, the individual mesh elements will be large relative to passageways. At a certain point, they will consider a narrow gap to be essentially closed.
    With higher resolution, relatively small gaps can be captured by the mesh and flow will move through.
    You can view the plane as a grid or array of points to get a sense of the mesh resolution (note this visualization option isn't yet available in the Revit plugin)
