Project Falcon
New Member
badoumba
Message 1 of 2 (194 Views)
Airfoil lift measurements
194 Views, 1 Replies
08-30-2013 05:10 AM
Hello
I have a project where I have to fine tune the shape of an airfoil for maximum lift and less turbulences as possible.
Does Flacon allows to measure the lift force in any way? Is this only be done by Velocity/Pressure color codes?
Employee
ryan.arnaudin
Message 2 of 2 (161 Views)
Re: Airfoil lift measurements
09-25-2013 06:31 PM in reply to: badoumba
Falcon will report drag and lift forces and the corresponding coefficients if you are running a 3D simulation and enable the "drag" option. You may also want to increase the resolution if you are making fine adjustments.
You are not logged in.
Announcements
Visit Autodesk Labs
Autodesk Labs is home for new prototypes, experiments, applications, and technologies.
Need installation help?
Ask the Community
