cmds.makeIdentity(apply=1)
if you create a simple nurbsCurve a circle, rotate it and then run this command it no longer works in maya 2015.
the same process does work in maya 2014 though.
anyone run into this issue?
or is this a major bug?
thanks!
so ive kept testing this seems to only work with mel.
not python.
which is not good.
Hi
I've just tried this in Maya 2015 SP1 and it seems to work fine. Have you tried upgrading to the latest service pack?
Mike
guys i was completley wrong.
i feel like an idiot.
it was not the makeIdentity command that was not working.
its cmds.parent(shapes=1) the way this behaves is different then from before.
i will post details when i have some more time.
been kinda busy.
sorry for the confusion.
