3ds Max Programming
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max SDK, Maxscript and Python topics.
Select CatParent in MaxScript
6 REPLIES 6
wagnerdesouza
486 Views, 6 Replies
How i can check if my object in the selection is a CatParent and not a CatBone?
6 REPLIES 6
Assuming a single object selected:-
if classof selection[1] == CatParent then
   -- it's a cat parent
else
   -- it's not
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
Yes! I have just one object selected.
Great, i will try this!
Works fine! Thanks!
What is the number 1 inside of selection[] ?
And, do you know the diference between Cat_Parent and CatParent?
Selection is an inbuilt array (well, technically a collection, but...) so if there's only 1 item selected it is in the 1st element of the array. [1] is an array index. Essentially the same using "$" i.e. classof $
Select an object, open the Maxscript Listener and type in "classof $" - if the selected object is a CatParent then that is what is displayed - literally. Also, the help has no entries for "Cat_Parent" but does for "CatParent" which is a bit of a clue 🙂
Max 2016 (SP1/EXT1)
Cool,
I understood, i was using $.
I tryed different ways ex.:
if $.category == CatParent then
if $.category == Cat_Parent then
if $category... etc
But the key was classOf 🙂
Next step is to parse the string of layer name of cat to set the timeline range 🙂
Iam very newbie in maxscript, so i have some doubts
Thanks for help!
Category is a somewhat different animal. Think of them as "groups" of objects of a similar type. A Box is part of the "#Standard_Primitives" category, a CatParent is part of the "#CAT_Objects" category and so on. Categories have their uses (they're used by the Display Panel "Hide by Category" for example) but aren't really specific enough for what you need in this instance.
Usage would be :- if $.category == #Standard_Primitives then...
Max 2016 (SP1/EXT1)
