How is it possible to import sketchbook pro files into inventor?
I don't want to know how to do it in designer due to Autodesk not making it anymore thanks.
Thanks in advance!
Solved by jannaspicer. Go to Solution.
SketchBook Pro exports the standard image formats:
TIFF
JPEG
PNG
BMP
The default file type that SketchBook Pro users is TIFF. Even though this supports layers, it should read into most systems as a flattened image. Any of the above mentioned formats are very transportable.
You will want to avoid the proprietary layer format types, such as PSD and PXD when moving image files to Inventor or other CAD packages.
Hope this helps.
Here are the step by step instructions:
From Sketchbook Pro, save your image as one of the Inventor-compatible formats: BMP GIF JPG PNG
From Inventor, create a new part, start a 2D Sketch, select one of the sketch planes, and from the Sketch menu on the Ribbon, select Insert Image (see red box below).
Select the image you saved from SketchBook Pro, and click OK. Then Finish Sketch.
Now you can use the SketchBook Pro image in your Inventor 2D sketch.
