Printing and Plotting
Distinguished Contributor
BenC
Message 1 of 7 (259 Views)
to print pdf with file name
259 Views, 6 Replies
03-13-2007 04:40 AM
I have quite a lot of pdf files to be printed. Is there anyway to print these out with the file name ? I am using the Acrobat reader 8.
*Dean Saadallah
Message 2 of 7 (259 Views)
Re: to print pdf with file name
03-13-2007 06:41 AM in reply to: BenC
No, the reader does not offer any writing abilities.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
BShick5088
Message 3 of 7 (259 Views)
03-13-2007 07:17 AM in reply to: BenC
Try publishing the drawings with the PostScript Level 1.pc3. In a separate file create a printer page setup that can be imported. (see my example named 24x36) The files will be dropped into your MyDocuments folder and will need to be renamed, but can be renamed easily. Then in Adobe use the distiller function to "watch a folder" and move the .EPS file into the IN folder of the watched folder. Adobe will automatically crunch the files into PDF's and place them into the OUT folder.
Hope this does the trick for you...
Brain
BenC
Message 4 of 7 (259 Views)
03-14-2007 04:40 AM in reply to: BenC
Thanks for the reply. I just want to printout pdf documents sent to me by others.
*Rodney McManamy
Message 5 of 7 (259 Views)
03-14-2007 04:25 PM in reply to: BenC
You could try www.cadfx.com. I don't remember if their replot adds on a
text watermark or not for the filename.
Otherwise Oce, KIP's and Metarprint's software I'm pretty sure will add on a
text watermark for the name or not.
Otherwise our AcroPlot can add on a watermark and create a new PDF file for
you.
Rodney McManamy
President
CADzation
CAD to PDF and DWF Solutions for Architects and Engineers
rmcmanamy@cadzation.com
http://www.cadzation.com
wrote in message news:5517760@discussion.autodesk.com...
others.
*ToniG
Message 6 of 7 (259 Views)
03-16-2007 01:42 PM in reply to: BenC
You may try our comercial tool...ripx
With the new verison V3.00.25 (available in about 1 week)
you can with a simple command do batch conversion or printing........
RIPX C:\Dokuments\Archive\*.PDF
Laserjet8550 –isprinter –windrv –bpp=24 –pos=cc
print out all PDF files in a directory to a colors laser jet .
(It works with any windows device, up to A3! For large format plotters ripx
has own drivers......)
More informations on our homepage....
http://www.tgsoft.ch/English/products/rip-x.htm
Regards
Toni
schrieb im Newsbeitrag news:5517760@discussion.autodesk.com...
others.
*Terry Drewes
Message 7 of 7 (259 Views)
03-27-2007 09:24 PM in reply to: BenC
A couple of ideas...
http://www.pdffactory.com/products/fineprint/index.html
http://support.adobe.com/devsup/devsup.nsf/docs/51412.htm
Acrobat Pro... Batch Routine
And others I'm sure... google search "batch print pdf"
Ciao!
~Terry
You are not logged in.
Announcements
Need installation help?
Ask the Community
