Printing and Plotting
Member
CarolM
Message 1 of 3 (118 Views)
rtext info changes with PUBLISH command
118 Views, 2 Replies
12-30-2004 09:48 AM
We use an in-house plotstamp (not the acad plotstamp) which uses rtext to show the file path and name. It works fine under all circumstances EXCEPT when we plot using the Publish command. The output from Publish shows the file path as the C:\Documents and Settings\... where the acad2005 software is installed instead of the correct network drive path where the dwg files are located.
Is there a secret setting somewhere that will keep Publish from changing the rtext? If we switch from rtext to fields, would that eliminate the problem?
Member
rhonda
Message 2 of 3 (118 Views)
Re: rtext info changes with PUBLISH command
03-03-2005 08:19 AM in reply to: CarolM
I am also having this problem. it is very frustrating. Does anyone have any ideas? Thanks, Rhonda
New Member
jseddon
Message 3 of 3 (62 Views)
08-20-2012 10:40 PM in reply to: CarolM
Try this
in the publish dialig box, remove all sheets from the default list & add / re-add the required drawing/layouts you wish to publish.
this seems to force autocad to source the files from their correct location & not c:\documents and settings\ LOCALS......
You are not logged in.
Announcements
Need installation help?
Ask the Community
