• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    Member
    plotting DWG To PDF - makes ACAD crash
    459 Views, 5 Replies
    04-12-2010 05:31 AM
    Hi, I am using AutoCAD LT 2010 on Windows 7 on an HP Compaq laptop.
    When I come to create a pdf from a drawing using 'DWG To PDF' from the plotter menu, AutoCAD often crashes, and it seems to be becoming more frequent.
    Normally shutting down the program and then re-starting it solves the problem, but sometimes I have to restart the computer (which is a significant loss of time). Today even doing that hasn't worked.
    Does anyone know what is going on here, and how to solve it?
    Thanks.
    Please use plain text.
    *Dean Saadallah
    Re: plotting DWG To PDF - makes ACAD crash
    04-12-2010 05:41 AM in reply to: Paul_Jolyon
    Remove and reinstall LT perhaps.
    Follow Autodesk's Uninstall AutoCAD instructions:
    http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=10243968&linkID=9240617
    or
    Grab REVO UNINSTALLER, it's free, and works better than Windows and software
    uninstallers ever could. Go for the maximum uninstall option, delete
    anything offered up with a delete option:
    http://www.download.com/Revo-Uninstaller/3000-2096_4-10687648.html?tag=mncol
    Then grab a freeware called CCLEANER and use it's default settings to clean
    up your Windows Registry ( also use it's Cleaner option to fix any issues
    with your PC).
    Now restart Windows, and reinstall LT with your two other apps turned off.
    Or try these other alternates:
    http://www.downloadsquad.com/2007/11/19/windows-add-remove-programs-replacements
    http://www.computerhope.com/issues/ch000568.htm
    http://windowsxp.mvps.org/AddRemove.htm
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;q247501
    Dean Saadallah
    http://LTisACAD.blogspot.com
    *MWhite
    04-16-2010 05:49 AM in reply to: Paul_Jolyon
    Paul,
    While I don't know the 'cause' and have repeated sought answers from
    various CAD gurus (gurii??) the workaround that we have developed is to
    go to DWF first. this unfortunately requires that you have either one
    of the higher-end Adopey products Pro or Standard, OR a 3rd party app
    like win2pdf or other ....
    we've been the route of remove/reinstall // format system and reinstall
    from the ground up. . . . eventually PDF creation goes bang.
    IMHO, PDF are a means to drive the majority of the CAD community insane
    waiting for plots while under deadline/pressure from bosses and clients
    Good Luck!
    Matt
    > Thanks.
    Member
    05-04-2010 06:33 AM in reply to: Paul_Jolyon
    Thanks for your reply Matt,
    I have tried plotting to DWF, but I don't have software which will open that filetype.
    I'll have to try re-installing ACAD when I can find time to go through with it...
    Cheers,
    Paul
    Member
    05-04-2010 07:02 AM in reply to: Paul_Jolyon
    Hi Dean,
    Thanks for your reply. I will (reluctantly) have to uninstall and reinstall ACAD as you suggest. It looks like my only option.
    Paul Edited by: Paul_Jolyon on May 4, 2010 2:04 PM
    *Dean Saadallah
    05-04-2010 07:58 AM in reply to: Paul_Jolyon
    Please back up all of your customizations, and do not try it if you have a
    major deadline looming.
    Dean Saadallah
