• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Printing and Plotting
    Valued Contributor
    pdf995 pdf landscape orientation - Solution!
    460 Views, 2 Replies
    07-06-2007 11:33 AM
    We are using pdf995 version 8.2s and pdfEdit995 to produce 11x17 pdfs. After a lot of trial and error we have figured out how to produce 11x17 landscape oriented pdfs that DON'T require rotation by the end user.
    1) In pdfEdit995 go to the rotate tab. The upper portion controls pdf995 - pick "Rotate all pages" (Ignore the bottom portion. It is for rotating existing pdfs and rotates the last created pdf.)
    2) In AutoCAD pick "Landscape" AND "Plot upside-down".
    This seems odd but it works for us with AutoCAD 2005.
    John
    Please use plain text.
    Member
    Re: pdf995 pdf landscape orientation - Solution!
    08-28-2007 05:49 AM in reply to: John7
    John,
    Thanks very much for posting this. I had just about given up on creating a with a landscape orientation when I came across your suggestion.
    And yes, it is odd.
    Thanks Again,
    Ben
    Contributor ti
    11-29-2012 05:41 AM in reply to: John7
    THANKS A LOT! This problem was driving me crazy!!! :smileywink:
    Edit: I also confirm that the solution works with AutoCAD 2011 too.
